Print Page | Close Window
Lisp create perspective view from a 2D drawing
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9594
Printed Date: 30.Oct.2026 at 03:02
Topic: Lisp create perspective view from a 2D drawing
Posted By: linhoreka
Subject: Lisp create perspective view from a 2D drawing
Date Posted: 01.Sep.2013 at 19:15
Hi, this lisp is working in 2D only: it generate a perspective view from a selected 2D plan or elevation.
http://www.mediafire.com/?eo84hfakoigh993" rel="nofollow - Download Lisp
http://www.mediafire.com/?acio7fqng641p9z" rel="nofollow - Example drawing
How to use ?
1. Command: P2D
2. Select the source frame (trapezoid polyline) of the plan or elevation
3. Select drawing objects in that source plan or elevation
4. Select destination frame >>> a new perspective drawing would be draw arcordingly (see image and example drawing)
5. Repeat step 4 until you select none
It is working only with straight lines, straight polylines and points. Pretty useful when you want to take a leap up from your 2D, for but donot have time to create a 3D model.
http://7cad.wordpress.com - AutoCAD lisps and VBA shared
