Print Page | Close Window
plot question
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9629
Printed Date: 03.Nov.2026 at 07:25
Topic: plot question
Posted By: Charlesdc54
Subject: plot question
Date Posted: 09.Sep.2013 at 22:58
I just switched to ACAD 2014 ( and inventor 2014) I am revising & plotting prints. The problem i am having is the plotter is set to Monochrome.stb when i plot some drawing i get a monochrome print, the next print will be shades of gray, frustrating. I have checked all the settings on both (it is a global setting) and it is the same on all prints.
On the gray sades I can fix by setting layers to white, but I like colors, as most of the time coping between layouts the base part and modifying is quicker if I see the layer to turn off.
Any Ideas on were to look for a screwed up setting?
Thanks
