Print Page | Close Window
I have some problem in Dimension
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9667
Printed Date: 20.Oct.2026 at 06:46
Topic: I have some problem in Dimension
Posted By: aruncmd
Subject: I have some problem in Dimension
Date Posted: 24.Sep.2013 at 10:18
Dear all,
When i was move any object with Dimension , the Dim will stress to old place to new place so how to correct this problem . but i select to hole not only object
Posted By: philippe JOSEPH
Date Posted: 24.Sep.2013 at 10:36
Hello aruncmd, I supose that your dimensions are associatives.
Take a look at this :
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS1a9193826455f5ffa23ce210c4a30acaf-62fb.htm,topicNumber=d0e126963" rel="nofollow - http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS1a9193826455f5ffa23ce210c4a30acaf-62fb.htm,topicNumber=d0e126963
You can rework the dimensions with the grips but it's recommanded not to move the drawing.
Posted By: aruncmd
Date Posted: 24.Sep.2013 at 11:50
THANK YOU FOR YOUR REPLAY
