low memory
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9694
Printed Date: 01.Nov.2026 at 08:43
Topic: low memory
Posted By: john3565
Subject: low memory
Date Posted: 04.Oct.2013 at 18:29
i am working in plant 3d but the file i saved .everytime i open it now it gives message low memory then eventually shuts down. it works fine on my laptop but using cad via a virtual server in work it crashes any idea
Posted By: John Connor
Date Posted: 04.Oct.2013 at 18:39
Is it a "low memory" error or an "out of memory" error?
Out of memory errors are typically due to insufficient virtual memory. VM is also known as the "swap file" which is a space set aside on a hard drive for Windows to swap data in and out of memory when the capacity of physical memory is near or at its peak. Seems like your IT department needs to do some housekeeping and clean up the space on the network drive you are operating off.
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
Posted By: john3565
Date Posted: 04.Oct.2013 at 19:01
spoken to the it dept and they have raised memory to 4gb but still low memory.they have tried to install on 64bit version but i still get same issue.the dwg file is 8,978 and opens ok on my laptop on 32 bit version. i know my it dept are struggling on this ,tht is why im trying here
Date Posted: 05.Oct.2013 at 12:45
So you have an 9MB drawing and you can open it on your laptop (how much memory?) but not on your desktop.
You never answered my question. Are you seeing an "out of memory" error or not?
If you are then the problem has nothing to do with the amount of physical memory per se but more to do with the size/location of the swap file which is also known as virtual memory.
<<AutoCAD 2015>>
Posted By: john3565
Date Posted: 07.Oct.2013 at 17:11
error is low memory. i have 4gb of ram on my laptop and 250gb drive running i5 dual core processor.tried to scrap itmes/layers on dwg but still same issue,i have tried other dgws and are ok,then when i render some dwg it gives same error
Date Posted: 07.Oct.2013 at 17:36
Rendering will definitely tax a system. Your computer would probably benefit from more RAM.
What OS are you running? Is it 32-bit or 64-bit?
<<AutoCAD 2015>>
Date Posted: 08.Oct.2013 at 17:11
Someone at another website suggested this as a fix. I cannot vouch for how well it works as I have 12GB of RAM and no low or out of memory problems.
Tools > Options dialog box, System tab, and change Layout Regen Options to
Cache model tab and last layout, click OK and restart AutoCAD
<<AutoCAD 2015>>
