Stacked dims in MTEXT
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9718
Printed Date: 28.Oct.2026 at 00:05
Topic: Stacked dims in MTEXT
Posted By: djrtx
Subject: Stacked dims in MTEXT
Date Posted: 13.Oct.2013 at 00:06
When using Mtext to create notes for details, fractional dimensions within the notes automatically stack. How do I make it stop doing this?
Posted By: John Connor
Date Posted: 13.Oct.2013 at 13:13
Isn't there an option to unstack fractions available via right-clicking while in the MTEXT editor? I'm not at my CAD computer at the moment so I cannot verify this.
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
Posted By: djrtx
Date Posted: 13.Oct.2013 at 15:30
That worked. I typed the fraction and it stacked automatically. Then I went back and highlighted the fraction, right clicked and selected "Stack Properties". Then selected "Auto Stack" in the lower right corner. Deselected "Enable Auto Stacking" in the next dialog box and hit "OK". That fixes it from that point forward. Thank you.
Posted By: heinsite
Date Posted: 15.Oct.2013 at 13:58
Open the mtext for editing and then select the stacked fraction and right-click it. In the menu - if the fraction is horizontally stacked - you should see an item called "stack properties". This is where you can change the display to the way you want it and save it as your default.
Dave.
------------- Dave Hein, P.E. Hawaii District Engineer Kona International Airport AutoCAD Certified Professional Autodesk Expert Elite
