Print Page | Close Window
AutoCAD Tip - Turn the ViewCube Off for New Drawings
Printed From: CAD Forum
Category: EN
Forum Name: RSS Feeds
Forum Description: Automatic publishing of CAD information from other web sources
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9721
Printed Date: 18.Apr.2026 at 15:25
Topic: AutoCAD Tip - Turn the ViewCube Off for New Drawings
Posted By: BetweenTheLines
Subject: AutoCAD Tip - Turn the ViewCube Off for New Drawings
Date Posted: 15.Oct.2013 at 08:02
So you mostly work in mostly 2D in AutoCAD, and you are asking "How can I set AutoCAD so that the 3D ViewCube is off when I start a new drawing"? Even in 2D drawing the ViewCube can be helpful in orienting the drawing, but if you really want to disable the ViewCube when you start a new drawing, read further for the solution. When you start a new drawing, AutoCAD uses a template (DWT). To change the ViewCube setting for new drawings, you only need to edit your template(s). Word of warning it is always a good thing to make a backup of existing files before overwriting them, just in case.
Go to the http://autodesk.blogs.com/between_the_lines/2013/10/turn-autocad-viewcube-off-for-new-dwgs.html - original post...
http://autodesk.blogs.com/between_the_lines/" rel="nofollow - Between the Lines - Autodesk blog by Shaan Hurley
