Print Page | Close Window
object not visible when switching Isometric why ?
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9735
Printed Date: 27.Oct.2026 at 13:33
Topic: object not visible when switching Isometric why ?
Posted By: VICTOR5
Subject: object not visible when switching Isometric why ?
Date Posted: 21.Oct.2013 at 09:47
Dear Experts,
I am using AutoCad 2013 & here i am facing a problem when i am switching my 2D view  to Isometric View. After Switching its showing nothing but when i am switching again to Plan view its appearing.
Would anyone help me here.
Thanks in advance.
Mohd. Irfan Khan
Posted By: philippe JOSEPH
Date Posted: 21.Oct.2013 at 11:17
Hello VICTOR5, maybe you have different objects at Z very different and when you switch to 3D they are so distant that they are very small at each end of your screen.
Try to do a selection to make the grips of your objects appear.
Posted By: John Connor
Date Posted: 21.Oct.2013 at 13:42
Did you try doing a Zoom > Extents?
<<AutoCAD 2015>>
Posted By: VICTOR5
Date Posted: 21.Oct.2013 at 14:20
ya, i tried zoom > extent .....but result is same
Mohd. Irfan Khan
Date Posted: 21.Oct.2013 at 14:59
In plan view did you check the Z values of your objects as previously suggested?
Upload a copy of the drawing so we can have a look ourselves.  Not an image but a DWG file.
<<AutoCAD 2015>>
Date Posted: 22.Oct.2013 at 23:55
We could solve the problem quicker if you responded in a more timely manner.  Move it soldier!
<<AutoCAD 2015>>
Posted By: jclong
Date Posted: 24.Oct.2013 at 19:52
I've seen this happen before when there is a clipping plane active that doesn't affect the plan view.
I get this problem often when using CAD files from Architects and Engineers from other companies.   It could also be that a clipping plane is defined in your ACAD Template File without you knowing it.
Use DVIEW and see if you can verify that clipping is off. If not, you can now turn it off from here.
