I have my own private time machine on my laptop I still run AutoCAD 2.18 from 1985/86 using a Virtual Machine running a 10Mb DOS partition. It is pretty amazing to try and use 1980 software today especially AutoCAD 2.18 without the UNDO command, Autosnaps, real time pan and zoom and so much more. You really realize how far CAD and design software has come. In AutoCAD 2.18 it was the first release with AutoLISP and only had 90 commands. I run AutoCAD 2.18 on a virtual machine of DOS 5 and a 10Mb disk size maximum otherwise AutoCAD 2.18 will not run. Apparently in 1985 the idea of a hard disk larger than 10Mb was crazy talk.
Here are a couple more screen shots and a quick video:
AutoCAD 2.18 Start MenuAutoCAD 2.18 and Space Shuttle Sample Drawing
If you want to try running Windows 1.0 or 1980 software for Apple check out these crazy web hosted virtual machines of software. Perhaps I should see about placing AutoCAD 2.18 in a web based virtual machine for people to try. Go to the http://autodesk.blogs.com/between_the_lines/2013/11/friday-flashback-run-1980s-software.html - original post...
------------- http://autodesk.blogs.com/between_the_lines/" rel="nofollow - Between the Lines - Autodesk blog by Shaan Hurley
