Print Page | Close Window
Converting Polylines to Arcs and Lines
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9778
Printed Date: 23.Oct.2026 at 13:47
Topic: Converting Polylines to Arcs and Lines
Posted By: rightdrawing
Subject: Converting Polylines to Arcs and Lines
Date Posted: 05.Nov.2013 at 17:15
My company has taken on an order for some decorative railings, which were drawn by the customer using polylines to make some eccentric shapes. The CAM software that we use, SigmaNest 7, does not like the polylines. The program simply crashes.
If there's any way of retaining the customer's shapes without effectively re-drawing their entire design, I'm all ears.
When I import one of the files into sigmanest, the program simply crashes. I did a quick and dirty cut-inch by replacing each shape with a polygon of about the same size, and they imported just fine as long as I deleted every polyline in the file.
I've run into a problem before where sigmanest will not handle polylines well, in that it will turn one into a complete circle despite having only a minor arc, but its easily handled by minor tweaks like deleting a redundant layer. I've never had sigmanest dislike a file so much that it just crashes.
Is my only option to redraw everything, or can I somehow convert those polylines into arcs and lines?
Thanks
Posted By: John Connor
Date Posted: 05.Nov.2013 at 18:16
Polylines can be exploded.
<<AutoCAD 2015>>
Date Posted: 05.Nov.2013 at 19:05
After I try to explode the railing, I get "cannot explode spline". I don't see any indication of elements being exploded, and I get the same crash (no helpful error messages).
Date Posted: 05.Nov.2013 at 19:17
Oh, you have splines not polylines?  Should have said so.  Convert the splines to a polylines using the SPLINEDIT command.
<<AutoCAD 2015>>
