Print Page | Close Window
Enhance the functionality of Autodesk® Revit with
Printed From: CAD Forum
Category: EN
Forum Name: Revit
Forum Description: Discussion about the BIM application Autodesk Revit (Architecture, Structure, MEP), Autodesk Forma
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9802
Printed Date: 14.Aug.2026 at 16:22
Topic: Enhance the functionality of Autodesk® Revit with
Posted By: 3dbim
Subject: Enhance the functionality of Autodesk® Revit with
Date Posted: 14.Nov.2013 at 14:16
Evox Parametrizer is a tool for Autodesk® Revit® BIM 2014 that brings huge advantages to modelers and managers as it improves the functions of Autodesk® Revit® by incorporating them with excel. The main functionality of this tool is to computerize the process and to connect an excel sheet to the setting of families, walls, floors and roofs.
After set up, a new menu will be visible in the tabs of Autodesk® Revit® facilitating the users to connect an excel sheet by means of some simple mouse clicks. Just select a a simple spreadsheet and generate the new family types by configuring parameters automatically. In case of revising the file, just update the information enclosed in the family at any time.
Evox Parametrizer also contains a wide array of exclusive features facilitating users to foresee various information concerning walls, floors and roofs from Autodesk® Revit® and to import them into another project as well as amend them simply by filling out an excel sheet.
Evox Parametrizer empowers users to interrelate in a better way with industry professionals and produce Autodesk® Revit® families of intelligent which can be upgraded in future.
Evox Parametrizer is well versed with Autodesk Revit 2014, Autodesk Revit Architecture 2014, Autodesk Revit MEP 2014and Autodesk Revit Structure 2014
http://bimoutsourcing.com/enhance-the-functionality-of-autodesk-revit-with-evox-parametrizer.php" rel="nofollow - Read More
Rajib Dey
BIM Consultant
www.bimoutsourcing.com (Leading BIM service provider)
