Print Page | Close Window
stl conversion to dwg
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9858
Printed Date: 29.Oct.2026 at 08:00
Topic: stl conversion to dwg
Posted By: clare8200
Subject: stl conversion to dwg
Date Posted: 02.Dec.2013 at 21:25
Hi,
Working on Autocad Mechanical 2013. I'm an inventor designing parts for my 3d printer, all works well except:
I've just used the utility here to convert some stl files to a dfx format. The converted files open, however instead of a closed object such as a gear being one part, it's over 2480 parts! Every faucet on the surface is a separate part.
With my limited knowledge in AutoCad concepts I've tried everything to convert these parts into usable objects but nothing seems to work. If I select the parts and "convert to solid" I get a notification that these parts can't be converted.
How would one combine all the thousands of parts that result when doing an stl conversion into simpler more usable objects?
Thanks in advance if anyone here could share some insight.
Posted By: rs_higgins
Date Posted: 17.Dec.2013 at 19:19
I not sure what tool you used to convert but this happens with some tools. Try Inventor Fusion 2013 R1 free from Autodesk. You open the file with Inventor Fusion then save as to change it to dwg, dxf, dwf, or an array of other formats. Big smile
No electrons were harmed in the making of this post. I will admit a few protons were momentarily Inconvenienced
Posted By: janetkissho
Date Posted: 26.Dec.2013 at 15:38
autodesk is a very good software for this work you can see more recommendations http://news.cision.com/dakota-digitalltd/r/back-office-pro-introduces-a-wide-range-of-new-engineering-services,c9446907" rel="nofollow - here .
Posted By: John Connor
Date Posted: 26.Dec.2013 at 16:18
AutoDesk is a company; Inventor is just one of the programs (software) they are responsible for.
<<AutoCAD 2015>>
Date Posted: 23.Jan.2014 at 17:18
I know the this post is old but the file for Inventor Fusion 2013 has moved and is hard to find
You can go here to get the Inventor Fusion 2013 free.
http://forums.autodesk.com/t5/Inventor-Fusion/Inventor-fusion-2013-R1-download-link/td-p/4299406
2nd comment.
There is a 32bit and 64bit insure that you download the correct version for you system.
Not confuse "Inventor Fusion 2013" with "Inventor"
Great For Converting files between most 3d software. Sorry it does not do PDF.Wink
