Print Page | Close Window
calculate cut and fill material quantities
Printed From: CAD Forum
Category: EN
Forum Name: Civil 3D, Map, InfraWorks
Forum Description: Discussion about mapping and GIS applications Map, Civil3D, InfraWorks, MapGuide and Raster Design
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9900
Printed Date: 28.Sep.2026 at 18:24
Topic: calculate cut and fill material quantities
Posted By: nickoh
Subject: calculate cut and fill material quantities
Date Posted: 14.Dec.2013 at 19:08
hi.
is there an easy way to calculate (better to say let the program calculate) cut and fill quantities from polylines?
i want to get something like a 3dmodel / volume based on contour lines (each contour line is made of several polylines that are not joined an have gaps in between. but they are on the correct level / z coordinates).
one volume for the existing and one for the designed landscape...
in the end i need all the cut material seperated from the fill-material.
last time (when i used autocad not map3d) i had to join all the polylines into one closed polyline (=one contour line)to get the area. and do this for each contour line and so on...
a lot of work which i hope is several klicks with map3d...
i am also thankful for links. i didnt find anything useful or didnt search for the right words...
thanks a lot
cheers
nickoh
