Print Page | Close Window
Text disappeared in AutoCAD 2011
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9931
Printed Date: 05.Sep.2026 at 06:11
Topic: Text disappeared in AutoCAD 2011
Posted By: BigRed
Subject: Text disappeared in AutoCAD 2011
Date Posted: 02.Jan.2014 at 17:23
I shut my computer down on December 30th and, when I returned on January 2nd, my AutoCAD files displayed no text.  This includes regular text and dimension text.  It is the same in model space and in paper space.  There is a grip where the text should be in dimensions, but there is nothing where the regular text should be.  When I open the files with DraftSight, the text is all there.  I am not aware of having changed anything.
What may be a clue to what happened is that, when I open a drawing, there are dozens of messages of the form, "** Undefined shape 50", with various numbers including 50.  I'd never seen this.  I can't deduce what is going on and I'm working with DraftSight today, just to get things done.
Am I the only one who thinks that AutoCAD 2011 is the worst version ever?  Things come unstuck that were nailed down 20 years ago.
Posted By: John Connor
Date Posted: 02.Jan.2014 at 18:15
I had a couple of serious problems with 2011 AutoCAD so I went back to 2010.
What font are you using?
Undefined shape may be referring to a shape file.  Did the text include any special characters?
<<AutoCAD 2015>>
Posted By: BigRed
Date Posted: 02.Jan.2014 at 18:50
Thank you for responding.
The non-displaying text includes Simplex, Standard and Sans Serif.  There may be other fonts.  There are no characters more exotic than ", ', and /.  Many of the non-displaying text entities have only letters and/or numbers.
They are on a common layer, but it is not frozen or off.  The associative dimensions are on the same layer.  The dimension lines and arrowheads are there, but there is a gap where the text should be.  The text is not so small that it can't be seen.  The text appears normally when the file is open in DraftSight.
Date Posted: 03.Jan.2014 at 00:31
Can you attach or upload a DWG file to this website?  I'd be willing to look at it.  I have both AutoCAD and DraftSight too.
<<AutoCAD 2015>>
Posted By: heinsite
Date Posted: 03.Jan.2014 at 08:45
Run an AUDIT on the damaged file and tell it to automatically fix any errors it finds.  See if that settles your issue.  You might also want to look for a .bak file.  If you find one, change the name to a .dwg with a different filename.  Open that and see if the trouble is still there.
Dave.
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
