Discussion forum
CAD discussion |
Date and time are not correct |
Post Reply |
Author | |
Wimm
Newbie Joined: 04.Apr.2024 Location: Nederland Using: 2021 Status: Offline Points: 2 |
Post Options
Thanks(0)
Posted: 04.Apr.2024 at 14:25 |
At the moment I have a problem with Autocad 2021 and that is that it does not want to save a drawing with the correct time and date in the explorer. When I open a drawing, for example UA.001 Existing condition of asphalt pavement, via the explorer and make changes to it and save it, the date and time remains the same as before opening! When I save the modified drawing 'via save as', the date and time do not change either! See appendix 01 The bizarre thing is that the changes in the drawing are saved. When I open Autocad and then use the command āopenā in this explorer, I see the correct date and time in the drawing when the changes were made and saved. See appendix 02. |
Vladimir Michl
Moderator Group Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2018 |
Post Options
Thanks(0)
Right click on the header in File Explorer and choose Modification Date instead of Date.
Vladimir Michl (moderator)
Arkance Systems - arkance-systems.cz - Autodesk reseller |
interscale
Newbie Joined: 23.Apr.2024 Location: Indonesia Using: AutoCAD2023 Status: Offline Points: 1 |
Post Options
Thanks(0)
kriperflag
Newbie Joined: 30.May.2024 Location: Germany Using: Revit2021 Status: Offline Points: 1 |
Post Options
Thanks(0)
In AutoCAD, thereās a system variable called FIELDEVAL which controls when fields in a drawing, such as the save date, are updated. Make sure itās set to update fields upon opening, saving, or plotting the drawing. You can adjust this setting by typing FIELDEVAL into the command line and setting its value to 31. AutoCAD 2024 2D and 3D drafting. Use āSaveDateā Field: Instead of using āCreateDateā, use the āSaveDateā field in your title blocks or text fields. This field should update upon saving the file. Edited by kriperflag - 01.Jun.2024 at 23:56 |
Post Reply | |
Tweet
This page was generated in 0,496 seconds.
