CAD tip CAD tip # 14033:
Question
The standard functions for clipping DWG geometry to a specific shape have a number of limitations. However, you can clip a view of any type of DWG geometry using the paper space - into any shape, not just rectangles (circles, ellipses, splines, islands).
You can use two methods:
  1. The command VPCLIP with the Polygon option, where you can then draw any shape of boundary curve to clip your drawing (model).
  2. The command MVIEW with the Object option, where you can convert any closed geometry into a boundary clipping object.
If you don't want to plot the clipping curve, place the viewport on a non-plotting layer (see layer properties).
Both methods are illustrated in the video:
ACADADTPlantACADMCivilMapACLT
18.2.2024   53474×   Rookie
this tip shared by ARKANCE experts applies to: ACAD · ADT · Plant · ACADM · Civil · Map · ACLT ·
Tip 15089:2DPlot - parametric math curves in AutoCAD.
Tip 14998:What is the difference between two open documents, two open Inventors, and two Inventors on two different PCs?
Tip 14991:Changing the order of rows in a table - sorting tables in AutoCAD.
Tip 14969:Examples of AI prompts and the challenges of using the Autodesk Assistant AI feature for analyzing and generating CAD geometry in AutoCAD and Fusion.
Tip 14944:How to import or export an SVG file in AutoCAD? (SVGimport/SVGexport)
Back    All CAD Tips
Categ:
