CAD tip # 11099:
Čísla buildů (verze DLL knihoven, verze v chybových hlášeních kompatibility, v dialozích O aplikaci) v jednotlivých verzích PDM aplikace Autodesk Vault:
| Verze Autodesk Vault | Build |
| Vault 2025 (RTM) | 30.0.91.0 |
| Vault 2024.2 | 29.2.88.0 |
| Vault 2024.1 | 29.1.83.0 |
| Vault 2024 (RTM) | 29.0.68.0 |
| Vault 2023.4 | 28.4.20.0 |
| Vault 2023.3 | 28.3.21.0 |
| Vault 2023.2 | 28.2.80.0 |
| Vault 2023.1 | 28.1.127.0 |
| Vault 2023 (RTM) | 28.0.83.0 |
| Vault 2022.5 | 27.5.14.0 |
| Vault 2022.4 | 27.4.13.0 |
| Vault 2022.3 | 27.3.24.0 |
| Vault 2022.2 | 27.2.67.0 |
| Vault 2022.1 | 27.1.90.0 |
| Vault 2022 (RTM) | 27.0.80.0 |
| Vault 2021.4 | 26.4.7.0 |
| Vault 2021.3 | 26.3.15.0 |
| Vault 2021.2 | 26.2.24.0 |
| Vault 2021.1 | 26.1.152.0 |
| Vault 2021 (RTM) | 26.0.63.0 |
| Vault 2020.4 | 25.4.4.0 |
| Vault 2020.3 | 25.3.22.0 |
| Vault 2020.2 | 25.2.83.0 |
| Vault 2020.1 | 25.1.55.0 |
| Vault 2020 (RTM) | 25.0.66.0 |
| Vault 2019.3 | 24.3.24.0 |
| Vault 2019.2 | 24.2.27.0 |
| Vault 2019.1 | 24.1.42.0 |
| Vault 2019 (RTM) | 24.0.49.0 |
| Vault 2018.3 | 23.3.21.0 |
| Vault 2018.2 | 23.2.3.0 |
| Vault 2018.1 | 23.1.1.0 |
| Vault 2018 (RTM) | 23.0.76.0 |
| Vault 2017.2 | 22.3.17.0 |
| Vault 2017.1 | 22.2.7.0 |
| Vault 2017 Pro+WG (RTM) | 22.0.56.0 |
| Vault 2017 Basic (RTM) | 22.0.48.0 |
| Vault 2016 (SP1) | 21.1.4.0 |
| Vault 2016 (RTM) Hotfix 1 | 21.0.59.10 |
| Vault 2016 (RTM) | 21.0.59.0 |
| Vault 2015 R2 (SP1) | 20.1.1.0 |
| Vault 2015 R2 (RTM) Hotfix 1 | 20.0.42.10 |
| Vault 2015 R2 (RTM) | 20.0.42.0 |
| Vault 2015 (SP2) | 19.2.2.0 |
| Vault 2015 (SP1) Hotfix 2 | 19.1.13.20 |
| Vault 2015 (SP1) Hotfix 1 | 19.1.13.10 |
| Vault 2015 (SP1) | 19.1.13.0 |
| Vault 2015 (RTM) | 19.0.49.0 |
| Vault 2014 Subscription Release 1 (SP2) | 18.102.3.0 |
| Vault 2014 Subscription Release 1 (SP1) | 18.101.3.0 |
| Vault 2014 Subscription Release 1 | 18.100.12.0 |
| Vault 2014 (SP3) | 18.3.2.0 |
| Vault 2014 (SP2) Hotfix 3 | 18.2.2.30 |
| Vault 2014 (SP2) Hotfix 2 | 18.2.2.20 |
| Vault 2014 (SP2) Hotfix 1 | 18.2.2.10 |
| Vault 2014 (SP2) | 18.2.2.0 |
| Vault 2014 (SP1) | 18.1.8.0 |
| Vault 2014 (RTM) Hotfix 1 | 18.0.110.0 |
| Vault 2014 (RTM) | 18.0.86.0 |
| Vault 2013 (SP1 Update 2) | 17.3.2.0 |
| Vault 2013 (SP1 Update 1) | 17.2.9.0 |
| Vault 2013 (SP1) | 17.1.16.0 |
| Vault 2013 (RTM) | 17.0.62.0 |
| Vault 2012 (Update 3) | 16.3.10.0 |
| Vault 2012 (Update 2) | 16.2.17.0 |
| Vault 2012 (Update 1) | 16.1.58 |
| Vault 2012 (RTM) | 16.0.56.0 |
| Vault 2011 (Update 2) | 15.2.66.0 |
| Vault 2011 (Update 1) | 15.1.58.0 |
| Vault 2011 (RTM) | 15.0.58.0 |
| Vault 2010 (Update 2) | 14.2.0.0 |
| Vault 2010 (Update 1) | 14.1.0.0 |
| Vault 2010 (RTM) | 14.0.63.0 |
| Vault 2009 (RTM) | 13.0.47.0 |
| Vault 2008 (SP1) | 12.1.145.0 |
| Vault 2008 (RTM) | 12.0.123.0 |
| Vault 5 (RTM) Hotfix 1 | 11.0.118.300 |
| Vault 5 (RTM) | 11.0.118.0 |
| Vault 4 (RTM) | 10.0.97.0 |
| Vault 3 (RTM) | 9.0.66.0 |
RTM=FCS=SP0 - původní uvedená verze
Číslo na čtvrtém místě čísla buildu se může lišit podle lokálních nebo jazykových hotfixů
Kontaktujte ARKANCE pro dotazy na kompatibilitu verzí Vaultu a vašich CAD aplikací.
tento tip od ARKANCE platí pro: Vault ·
Co je komunita ARKANCE?
also in ENGLISH
AutoCAD LT
Vault
