CAD tip # 9269:
Cloud aplikace řady BIM 360 - Autodesk BIM 360 Glue - podporuje následující souborové 3D a 2D CAD formáty, resp. zdrojové CAD aplikace:
| Autodesk aplikace | |
| AutoCAD (2008-2014+) | .DWG, .DWF, .DWFx, .DXF, .3DS, .FBX |
| AutoCAD Architecture (2008-2014+) | .DWG, .DWF, .DWFx, .DXF, .3DS, .FBX |
| AutoCAD MEP (2008-2014+) | .DWG, .DWF, .DWFx, .DXF, .3DS, .FBX |
| AutoCAD Plant 3D (2010-2014+) | .DWG, .DWF, .DWFx, .DXF, .3DS, .FBX |
| Autodesk CAD-Duct | .DWG, .DXF, .3DS |
| Autodesk Navisworks Manage (2008-2014+) | .NWD, .NWC, .NWF , .DWF |
| Autodesk Inventor R5 až R11 a 2009-2014+ | .IPT, .IAM, .IPJ, .IGES, .STEP, .JT, .FBX |
| AutoCAD Civil 3D (2008-2014+) | .DWG, .DWF, .DWFx, .DXF, .3DS, .FBX |
| MDT (8 až 2009) | .DWG, .DXF, .3DS, .VRML |
| Revit Architecture (2008-2014+) | .DWG, .DWF, .DWFx, .DXF, .DGN, .FBX |
| Revit Structure (2008-2014+) | .DWG, .DWF, .DWFx, .DXF, .DGN, .FBX, .CIS/2 |
| Revit MEP (2008-2014+) | .DWG, .DWF, .DWFx, .DXF, .DGN, .FBX |
| Autodesk 3ds Max 8 až 2014+ | .DWG, .DXF, .3DS, .IGES, .FBX |
| Autodesk VIZ 2008 | .DWG, .DXF, .3DS |
| Autodesk Maya | .DXF, .IGES, .VRML |
| Bentley | |
| AutoPLANT | .DWG, .DXF, .3DS |
| MicroStation J | .DWG, .DXF, .DGN, .IGES, .STEP, .VRML |
| MicroStation v8 až 8.5, XM (8.9) | .DWG, .DXF, .DGN, .IGES, .STEP, .VRML |
| ProSteel 3D | .DWG, .DXF, .3DS, .CIS/2 |
| TriForma J | .DWG, .DXF, .DGN, .IGES, .STEP, .VRML |
| TriForma v8 až 8.9 | .DWG, .DXF, .DGN, .IGES, .STEP, .VRML |
| Graphisoft | |
| ArchiCAD 10 až 16 | .DWG, .DXF, .DGN, .IFC |
| Constructor 2007 až 2010 | .DWG, .DXF, .DGN |
| AceCad | |
| StruCad | .DXF, .CIS/2 |
| auto.des.sys | |
| form.z | .DWG, .DXF, .3DS, .IGES, .STL, .VRML |
| AEC | |
| CADPIPE | .DWG, .DXF, .3DS |
| AVEVA | |
| PDMS | .RVM |
| CADopia | |
| IntelliCAD | .DWG, .DXF |
| CEA Technology | |
| Plant-4D | .DWG, .DGN |
| COADE, Inc. | |
| CADWorx Plant | .DWG, .DXF, .3DS |
| CADWorx Pipe | .DWG, .DXF, .3DS |
| CADWorx Steel | .DWG, .DXF, .3DS |
| COINS | |
| BSLink | .DWG, .DXF, .3DS |
| Framing | .DWG, .DXF, .3DS |
| CSC | |
| 3D+ | .DWG, .CIS/2 |
| Dassault Systemes | |
| CATIA | .DXF, .IGES, .STEP, .JT |
| Hannappel SOFTWARE GmbH | |
| elcoCAD R4 | .DWG, .DXF, .3DS |
| Intergraph | |
| PDS | .DWG, .DXF, .DGN, .IGES, .STEP |
| Informatix | |
| MicroGDS | .MAN |
| ITandFactory | |
| CADISON | .DXF, .3DS |
| TRICAD MS | .VRML |
| Kubotek USA | |
| CADKEY | .DWG, .DXF, .IGES, .STEP |
| M.A.P. | |
| McNeel North America | |
| Rhino | .DWG, .DXF, .3DS, .IGES, .STEP |
| Mensch und Maschine | |
| RoCAD | .DWG, .DXF, .3DS |
| MultiSUITE | |
| MultiSTEEL | .DWG, .DXF, .3DS |
| Nemetschek | |
| Allplan | .DWG, .DXF, .DGN, .IFC |
| PROCAD | |
| 3DSMART | .DWG, .DXF, .3DS |
| PTC | |
| Pro/ENGINEER | .IGES, .STEP, .VRML, .JT |
| CADDS 5 | .IGES, .STEP |
| QuickPen | |
| PipeDesigner 3D | .DWG, .DXF, .3DS |
| DuctDesigner 3D | .DWG, .DXF, .3DS |
| RAM International | |
| CADstudio | .DWG, .DXF, .3DS |
| SolidWorks | |
| SolidWorks | .DWG, .DXF, .IGES, .STEP, .VRML, .JT |
| Trimble | |
| Tekla Structures | .DGN, .VRML, .CIS/2 |
| Xsteel | .DGN |
| SketchUp (až do V7) | .SKP, .DWG, .3DS |
| think3 | |
| thinkdesign | .DWG, .DXF, .IGES, .STEP |
| UGS | |
| I-deas | .DXF, .IGES, .STEP, .JT |
| Solid Edge | .IGES, .STEP, .JT |
| NX (Unigraphics) | .DXF, .IGES, .STEP, .JT |
| FactoryCAD | .DWG, .DXF, .3DS |
| UHP Process Piping | |
| AFabPro Pipe | .DWG, .DXF, .3DS |
| X-plant | .DWG, .DXF, .3DS |
| 2D formáty | |
| Autodesk AutoCAD | .DWG |
| Autodesk DWF | .DWF, .DWFx |
| Laser Scan formáty | |
| ASCII Laser File | .ASC, .TXT |
| Faro | .FLS, .FWS, .iQSCAN, .iQMOD, .iQWSP |
| Leica | .PTS, .PTX |
| Riegl | .3DD |
| Z+F | .ZFC, .ZFS |
Co je komunita ARKANCE?
also in ENGLISH
Navisworks
BIM 360/ACC
