  právě nás čte: 7202
CAD tip CAD tip # 1386:
Přehled vlastností objektů Architectural Desktopu.
A - odpověď Pro účely uživatelských úprav a přizpůsobení může být užitečná tabulka automatických vlastností dostupných u jednotlivých typů objektů Architectural Desktopu R3.
2D Section/Elevation
    Description
    Style
3D Face
    Area
AEC Dimension
    Description
AEC Polygon
    Description
    Edge Perimeter
    Edge Width
    Gross Area
    Infill Area
    Infill Perimeter
    Justification
    Style
Arc
    Area
    Included Angle
    Length
    Radius
Area
    Base Area
    Base Perimeter
    Calculated Area
    Calculated Perimeter
    Calculation Modifier
    Description
    Name
    Style
Area Group
    Base Area
    Base Perimeter
    Calculated Area
    Description
    Name
    Style
Attribute Definition
    Text
Bldg Elevation Line
    Description
Bldg Section
    Description
Bldg Section Line
    Description
Block Reference
    Name
    Path
    Position X
    Position Y
    Position Z
    Rotation
    X Scale
    Y Scale
    Z Scale
Camera
    Angle Of View
    Description
    Location X
    Location Y
    Location Z
    Name
    Target Dist
    Target X
    Target Y
    Target Z
    Zoom
Ceiling Grid
    Description
Circle
    Area
    Circumference
    Radius
Clip Volume
    Description
Clip Volume Result
    Description
Column Grid
    Description
Curtain Wall
    Base Curve Radius
    Cell Count
    Description
    Edge Count
    Height
    Length
    Style
Curtain Wall Unit
    Base Curve Radius
    Cell Count
    Description
    Edge Count
    Height
    Length
    Style
Door
    Description
    Door Size - 2@ WxH
    Door Size - 2@ WxHxT
    Door Size - WxH
    Door Size - WxHxT
    Frame Depth
    Frame Width
    Head Height
    Height
    Leaf Width
    Rise
    Rough Height
    Rough Width
    Sill Height
    Style
    Swing Direction
    Thickness
    Width
    Width - 2@
Ellipse
    Area
    Circumference
    Major Length
    Minor Length
Entity Reference
    Description
Grid Assembly
    Description
Hatch
    Name
Layout Curve
    Description
Layout Grid 2D
    Description
Layout Grid 3D
    Description
Line
    Length
Mask Block Reference
    Description
    Name
    Notes from Definition
    Position X
    Position Y
    Position Z
    X Scale
    Y Scale
    Z Scale
Mass Element
    Description
    Group Name
    Height
    Length
    Profile Name
    Radius
    Rise
    Type
    Volume
    Width
Mass Group
    Description
    Name
    Volume
MInsert Block
    Count
    Name
    Path
    Position X
    Position Y
    Position Z
    Rotation
    X Scale
    Y Scale
    Z Scale
MLine
    Length
    Style
MText
    Text
Multi-View Block Reference
    Description
    Name
    Position X
    Position Y
    Position Z
    X Scale
    Y Scale
    Z Scale
Opening
    Description
    Head Height
    Height
    Profile Name
    Rise
    Rough Height
    Rough Width
    Sill Height
    Width
Polyline
    Area
    Closed
    Elevation
    Length
    Thickness
Polyline (2D)
    Area
    Closed
    Elevation
    Length
    Thickness
Polyline (3D)
    Area
    Length
Railing
    Baluster Count
    Baluster Depth
    Baluster Max Spacing
    Baluster Profile
    Baluster Rotation
    Baluster Width
    Bottomrail Count
    Bottomrail Depth
    Bottomrail Height
    Bottomrail Length
    Bottomrail Profile
    Bottomrail Sloping Height
    Bottomrail Spacing
    Bottomrail Width
    Description
    Dynamic Post Count
    Dynamic Post Depth
    Dynamic Post Max Spacing
    Dynamic Post Profile
    Dynamic Post Rotation
    Dynamic Post Width
    Fixed Post Count
    Fixed Post Depth
    Fixed Post Profile
    Fixed Post Rotation
    Fixed Post Width
    Fixed Posts at Corners
    Guardrail Count
    Guardrail Depth
    Guardrail Height
    Guardrail Length
    Guardrail Offset
    Guardrail Placement
    Guardrail Profile
    Guardrail Sloping Height
    Guardrail Width
    Handrail Count
    Handrail Depth
    Handrail Height
    Handrail Length
    Handrail Offset
    Handrail Placement
    Handrail Profile
    Handrail Sloping Height
    Handrail Width
    Post Count
    Post Extension
    Style
Region
    Area
Roof
    Description
    Overhang
    Thickness
Roof Slab
    Area - Gross
    Area - Net
    Baseline Fascia Profile
    Baseline Length
    Baseline Overhang
    Baseline Soffit Profile
    Description
    Elevation - High
    Elevation - Low
    Non-Baseline Fascia Profile
    Non-Baseline Length
    Non-Baseline Overhang
    Non-Baseline Soffit Profile
    Perimeter
    Rise
    Rise/Run
    Run
    Slope
    Style
    Thickness
    Volume
Schedule Table
    Description
Slab
    Area - Gross
    Area - Net
    Baseline Length
    Baseline Overhang
    Description
    Elevation - High
    Elevation - Low
    Non-Baseline Length
    Perimeter
    Rise
    Rise/Run
    Run
    Slope
    Style
    Thickness
    Volume
Slice
    Area
    Description
    Elevation
Solid (2D)
    Area
Solid (3D)
    Volume
Space
    Base Area
    Ceiling Thickness
    Description
    Floor Thickness
    Height
    Length
    Maximum Area
    Maximum Length
    Maximum Width
    Minimum Area
    Minimum Length
    Minimum Width
    Net Ceiling Area
    Net Floor Area
    Space Above Ceiling
    Style
    Width
Space Boundary
    Description
    Type
    Width
Spline
    Area
    Length
Stair
    Description
    Floor to Floor
    Inner Spiral Radius
    Landing Count
    Landing Dimensions
    Nosing
    Open/Closed
    Outer Spiral Radius
    Rise
    Riser Thickness
    Risers
    Shape
    Spiral Angle per Step
    Spiral Total Angle
    Stringer Quantity
    Stringer Total Depth At Flight
    Stringer Total Depth At Landing
    Stringer Type
    Stringer Waist Depth At Flight
    Stringer Waist Depth At Landing
    Stringer Width
    Style
    Tread
    Tread Count
    Tread Thickness
    Width
Structural Member
    Description
    End Offset
    Justification
    Length
    Member Type
    Roll
    Shape Designation (*VARIES*)
    Shape Designation (List)
    Start Offset
    Style
Text
    Text
Wall
    Area - Left Gross
    Area - Left Net
    Area - Right Gross
    Area - Right Net
    Description
    Height
    Length
    Style
    Volume - Gross
    Volume - Net
    Width
Window
    Description
    Frame Depth
    Frame Width
    Head Height
    Height
    Leaf Width
    Rise
    Rough Height
    Rough Width
    Sill Height
    Style
    Width
Window Assembly
    Base Curve Radius
    Cell Count
    Description
    Edge Count
    Head Height
    Height
    Length
    Rise
    Sill Height
    Style
ADT3
13.6.2001    5217×
reference text vlastnosti
Ceny - CAD eShop:
platí pro: AutoCAD Architecture 3 ·
