  Visitors: 5268
CAD tip CAD tip # 8306:
Free 3D CAD software.
A - answer I am a crafter/hobbyist ("maker") - where can I find a good 3D CAD software which is inexpensive or even free?
For your maker activities, you can download and use e.g. the free 3D CAD modeler and fabrication tools based on Autodesk Inventor Fusion - Autodesk 123D Design and 123D Make.
"123D" is a family of free 3D solid modeling and fabrication software tools based on the same Autodesk technology used by millions of designers and engineers worldwide. Autodesk 123D is easy to use - you can design precise and makeable objects using smart tools that let you start with simple shapes and then edit them into more complex shapes. The Windows, Mac and cloud/mobile applications "123D" support many standard file formats.
You can also combine "123D Design" with "123D Catch" (Photofly/Photo Scene Editor) to make a 3D model of a real-world object from a series of photos.
For 2D CAD work you can use another Autodesk simple and free tool - the cloud version of AutoCAD - AutoCAD 360 (WS).
You can also use a free version (for makers) of the advanced 3D CAD/CAM/CAE tool - Autodesk Fusion 360.
DWGInvACAD
7.11.2011    25051×   FAQ
Prices - CAD eShop:
applies to: DWG · Inventor · AutoCAD ·
Tip 14093:3D terrain model of any place in Czechia - elevation data by the Czech Land Survey Office (CUZK) into Civil 3D.
Tip 14075:Overview of CAD formats supported in Inventor 2025 (import/export/AnyCAD).
Tip 14059:Import coordinates from CSV files into Fusion profiles.
Tip 14027:3D heart from the heart.
Tip 14022:Comparing design versions in Autodesk Fusion.
