  Visitors: 6090
CAD tip CAD tip # 10842:
HidePStyle - completely hide selected plot style for printing.
A - answer The AutoCAD plot style editor (STB) doesn't provide a way for hiding a given plot style completely. You always get at least 10% screening or white lines on a colored background.
If you need to completely and temporarily hide selected plot styles, you can use the HidePStyle add-on utility. Get it from Download, load the VLX file with APPLOAD and start the HidePStyle command. Enter the plot style name or pick a sample object. All DWG objects with this plot style assigned will be hidden temporarily (for display and print) in the current drawing. You can redisplay them either with UNISOLATEOBJECTS (2011+) or ShowPStyle (in 2010 and earlier).
ACADADTACADMPlantCivilMap
15.4.2016    14155×
Tip 10444:How to hide system printers in AutoCAD PLOT dialog?
Tip 8088:How to hide the frame of a PDF underlay?
Tip 3908:Some network printers are not offered by AutoCAD for plotting.
Tip 3232:My texts are printed as outlines only (hollow).
Tip 3045:Views with hidden lines are plotted with wrong linewidths (widths are ignored).
