Téma uzavřenoUveden SP3 pro AutoCAD Map 3D 2015
Bodů: 22247
Přímý odkaz na tuto zprávu Téma: Uveden SP3 pro AutoCAD Map 3D 2015
    Zasláno: 17.říj.2014 v 23:01
Byl uveden Service Pack 3 pro AutoCAD Map 3D 2015 (obsahuje i SP1 a SP2). Ke stažení je na stránce Download.
Přehled oprav:
Primary Issues Resolved by Service Pack 3
Bulk Copy
  • Bulk Copy may not work properly when selecting the source as a layer of the current drawing.
Industry Model
  • The auto created feature label will move to the originally defined location when editing the feature attribute in Map 3D.
  • Lines and Points need minutes to highlight all from form.
  • Updating from excel may fail if the key coloumn in the excel has '#' as prefix.
  • Sometimes Map 3D pops up eLockViolation message when generating grahpic.
FDO WFS
  • Map 3D cannot read the feature class information from the WFS server if it has too many feature classes, as the sending request would be too long.
  • FDO WFS cannot support some multiple surface geometry.
Options
  • Map 3D 2015 does not accept cyrillic characters in path.
Others
  • User cannot duplicate the layout tab by using the CTRL key.
  • In certain cases, Block Editor toolbar does not disappear from view when exiting the Block Editor.
  • On Windows 8/8.1, AutoCAD Map 3D fails to work when user clicks Query Current Drawing.
Tip 5225:Podporuje Autodesk Map databázi Oracle 10g?
Tip 9893:KRITICKÁ CHYBA: Unhandled Access Violation Reading XXXX Exception at YYYY
Tip 9929:Problém s připojením na WMS služby z AutoCADu Map 3D 2015.
Tip 5269:Kompatibilita Raster Design 2007 SP1 s CAD aplikacemi.
Tip 9902:Nefungující příkaz MAPTRIM v AutoCADu Civil 3D 2015 CZ (Nelze inicializovat dialog).
Tip 10120:Nefungující připojení na WMS zdroj dat v Civil3D 2015.
Stránka byla vygenerována za 0,250 sekund.
