Téma uzavřenoUveden Service Pack 2 pro Civil3D 2015
Bodů: 22257
Přímý odkaz na tuto zprávu Téma: Uveden Service Pack 2 pro Civil3D 2015
    Zasláno: 03.pro.2014 v 13:01
Byl uveden druhý Service Pack pro AutoCAD Civil 3D 2015. Obsahuje i veškeré aktualizace ze SP1 a aktualizace AutoCAD SP2, plus Map3D SP3 a opravu Bing geolokace. Ke stažení jej najdete na stránce Download.
Samotné opravy Civil funkcí zahrnují:
The following issues have been resolved in Autodesk AutoCAD Civil 3D 2015 Service Pack 2:
Alignments and Profiles
  • An issue has been resolved where opening an AutoCAD Civil 3D 2012 drawing in AutoCAD Civil 3D 2014 or AutoCAD Civil 3D 2015 caused profiles to shift unexpectedly.
  • An issue has been resolved where opening a drawing that contains corrupted profile views caused the application to close unexpectedly.
  • An issue has been resolved where horizontal grid lines in profile views were extended into the axis offset.
  • An issue has been resolved where a fixed parabolic vertical curve was lost when exported to LandXML and then imported back into AutoCAD Civil 3D.
  • An issue has been resolved where station/elevation values in an Autodesk® InfraWorks™ profile were not converted from feet to meters when importing an imperial IMX file into a metric AutoCAD Civil 3D drawing.
  • An issue has been resolved where the Autodesk® Civil Engineering Data Translator did not include certain profile layout configurations when exporting drawings to files that can be used in Bentley® GEOPAK® or Bentley® InRoads®.
  • An issue has been resolved where the Export Civil 3D Drawing command would export alignments as lines and arcs instead of polylines when exporting to a DGN file.
  • An issue has been resolved where unexpected solid objects were projected to a section view.
  • An issue has been resolved where a projected solid extended above or below section views and profile views.
  • An issue has been resolved where full superelevation critical point labels were not drawn in certain situations.
  • An issue has been resolved where the Export LandXML command output incorrect station equations for alignments that included more than three station equations.
  • An issue has been resolved where the Alignment.EndingStation API property returned raw stations when there were station equations in the alignment.
  • An issue has been resolved where station equations could not be added to end of an alignment.
  • An issue has been resolved where a profile may be missing when a drawing is exported to GEOPAK using the Autodesk Civil Engineering Data Translator.
  • The AutoCAD Civil 3D API has been extended to enable superelevation data to be imported from an external file.
Corridor Modeling
  • An issue has been resolved where the Swept Solids option in the Extract Corridor Solids command only included links and did not include shapes.
  • An issue has been resolved with the search path of the subassembly codes file.
  • An issue has been resolved where the Extract Corridor Solids command did not include the correct corridor shape code names as part of the layer names for the solids.
  • An issue has been resolved where corridor feature lines were not using the code set styles assigned to the corridor.
  • An issue has been resolved where the material refill factor value in the Edit Material List dialog box was blank and would not preserve an assigned value.
Feature Lines, Parcels, and Sites
  • An issue has been resolved where feature lines and their site would disappear when moved to a different site in drawings created from acad.dwt.
  • An issue has been resolved where using the Insert Intermediate Grade Break Points option in the Elevations From Surface command would result in errors in the drawing.
  • An issue has been resolved where invalid characters were added to feature line and alignment names in certain cases.
  • An issue has been resolved where the Export Civil 3D Drawing command would export corridor feature lines as lines instead of polylines when exporting to a DGN file.
  • An issue has been resolved where copying a parcel to another site would delete the source site in drawings created from acad.dwt.
  • An issue has been resolved with crow's feet in parcel labels when a parcel intersects itself.
Miscellaneous
  • An issue has been resolved where north arrows were not adjusting to north if sheets were created in the current drawing with the Create Sheets command.
  • An issue has been resolved where layers created from styles did not include the definitions for transparency and plot style.
  • An issue has been resolved where labels for data-referenced surfaces were not appearing when drawings were opened.
  • An issue has been resolved where Cyrillic characters were not accepted when entering path information for the AutoCAD Support File Search Path.
  • An issue has been resolved when attempting to connect to WMS using the AutoCAD Map 3D Connect command.
  • An issue has been resolved where users may not have been able to export a drawing to DGN using the Export Civil 3D Drawing command when MicroStation® was installed.
  • An issue has been resolved where note labels could not be copied from one drawing to another.
  • An issue has been resolved where descriptions defined for Toolbox items were being displayed as tooltips for Toolbox items.
  • An issue has been resolved where referenced drawings that contained hatches were plotting differently than the source drawings.
Pipe Networks and Pressure Networks
  • An issue has been resolved where the Break Pipe command for pressure pipes may not have worked as expected.
  • An issue has been resolved where connecting a pipe to an existing circular structure may have reset the structure size to the smallest size in its family.
  • An issue has been resolved where structures with 0' (0m) sump depth may have been drawn incorrectly in profile view.
  • An issue has been resolved where an Optional Property for a pipe or structure was not retained.
  • An issue has been resolved with the performance of opening drawings in certain cases where the drawings included data-referenced pipe networks.
  • An issue has been resolved where using the Select command from the Pipes or Structures collections in the Prospector tree did not select the pipes and structures in the drawing.
  • An issue has been resolved where materials could not be selected from the drop-down list when using specific parts lists.
  • An issue has been resolved where only two materials could be added into the drop-down list when adding parts to a part list in a metric drawing.
Points, Surfaces, and Survey
  • An issue has been resolved where user-defined properties were removed from all COGO points after deleting and then undoing the deletion of a single COGO point.
  • An issue has been resolved where the Build option Maximum Angle Between Adjacent TIN Lines on the Definition tab of the Surface Properties dialog box was not saved when a drawing was reopened.
  • An issue has been resolved in cases where there was a large angular error in survey traverse analysis.
  • Warning icons are now displayed for survey figures in the following situations:
    • If a figure contains only two consecutive curve vertices.
    • If there is an issue with the geometric information for a figure that is imported from an FBK file.
    The warning icons are displayed on the Figures collection on the Survey tab in Toolspace and for individual figures in the Toolspace item view and in the Figures Editor.
Vault
  • An issue has been resolved where an unexpected error would occur when checking in a drawing using Autodesk® Vault 2015 R2 Server.
  • An issue has been resolved where revisions of xrefs were not managed correctly when using Autodesk Vault.
  • An issue has been resolved with Autodesk Vault performance when opening a sheet set within AutoCAD Civil 3D in cases where multiple projects are displayed in the Prospector tree.
Water Analysis
  • An issue has been resolved where the graphic plot for an inlet section in Hydraflow Storm Sewers listed the units for inlet depth incorrectly.
  • An issue has been resolved where junction loss was not properly computed in Hydraflow Storm Sewers.
Bodů: 22257
Přímý odkaz na tuto zprávu Zasláno: 03.pro.2014 v 13:25
Další informace a zkušenosti se SP2 doplní ještě kolega Martin Folber na blogu Civil3D.cz
Tip 10120:Nefungující připojení na WMS zdroj dat v Civil3D 2015.
Tip 10009:Nefunguje mi kopie rozvržení pomocí Ctrl+přetažení v AutoCADu 2015.
Tip 10542:Nefungují náhledy ve Vault klientu v MSIE10.
Tip 10034:Po přepnutí do prostředí jednoho dokumentu nezná AutoCAD Electrical některé příkazy.
Tip 9929:Problém s připojením na WMS služby z AutoCADu Map 3D 2015.
Tip 9900:Po výběru objektů v Maya 2015 for Mac mi zčerná plocha výřezu.
Stránka byla vygenerována za 0,809 sekund.
