Téma uzavřenoProblem s MapGuidem
imzadi Zobrazit panel
Přihlášen: 25.čvc.2006
Civil 3D 2009
Bodů: 116
Přímý odkaz na tuto zprávu Téma: Problem s MapGuidem
    Zasláno: 05.bře.2007 v 14:00
Nevite nekdo, jestli MapGuide Studio umi pracovat s J-TSK?
pise mi to tuto hlasku:
The coordinate system is invalid. PROJCS["S-JTSK (Ferro) / Krovak", GEOGCS [ "S-JTSK (Ferro)", DATUM ["S-JTSK (Ferro) (EPSG ID 6818)", SPHEROID ["Bessel 1841 (EPSG ID 7004)", 6377397.155, 299.1528128]], PRIMEM [ "Ferro", -17.666667 ], UNIT ["Decimal Degree", 0.01745329251994328]], PROJECTION ["Krovak (EPSG OP 19952)"], UNIT ["Meter", 1]] Could not convert OGC WKT to Mentor. wktFlvrNone - Flavor of WKT string named 'S-JTSK (Ferro) / Krovak' could not be determined. wktFlvrOgc - The PROJECTION specification contained within the text presented as a WKT definition specified an unsupported projection (Krovak (EPSG OP 19952)). wktFlvrGeoTiff - The PROJECTION specification contained within the text presented as a WKT definition specified an unsupported projection (Krovak (EPSG OP 19952)). wktFlvrEsri - The PROJECTION specification contained within the text presented as a WKT definition specified an unsupported projection (Krovak (EPSG OP 19952)). wktFlvrOracle - The PROJECTION specification contained within the text presented as a WKT definition specified an unsupported projection (Krovak (EPSG OP 19952)). wktFlvrGeoTools - The PROJECTION specification contained within the text presented as a WKT definition specified an unsupported projection (Krovak (EPSG OP 19952)). wktFlvrEpsg - The PROJECTION specification contained within the text presented as a WKT definition specified an unsupported projection (Krovak (EPSG OP 19952)). None of the Mentor flavors could parse the specified OGC WKT.
The coordinate system is invalid. PROJCS["S-JTSK (Ferro) / Krovak", GEOGCS [ "S-JTSK (Ferro)", DATUM ["S-JTSK (Ferro) (EPSG ID 6818)", SPHEROID ["Bessel 1841 (EPSG ID 7004)", 6377397.155, 299.1528128]], PRIMEM [ "Ferro", -17.666667 ], UNIT ["Decimal Degree", 0.01745329251994328]], PROJECTION ["Krovak (EPSG OP 19952)"], UNIT ["Meter", 1]] Could not convert OGC WKT to Mentor. wktFlvrNone - Flavor of WKT string named 'S-JTSK (Ferro) / Krovak' could not be determined. wktFlvrOgc - The PROJECTION specification contained within the text presented as a WKT definition specified an unsupported projection (Krovak (EPSG OP 19952)). wktFlvrGeoTiff - The PROJECTION specification contained within the text presented as a WKT definition specified an unsupported projection (Krovak (EPSG OP 19952)). wktFlvrEsri - The PROJECTION specification contained within the text presented as a WKT definition specified an unsupported projection (Krovak (EPSG OP 19952)). wktFlvrOracle - The PROJECTION specification contained within the text presented as a WKT definition specified an unsupported projection (Krovak (EPSG OP 19952)). wktFlvrGeoTools - The PROJECTION specification contained within the text presented as a WKT definition specified an unsupported projection (Krovak (EPSG OP 19952)). wktFlvrEpsg - The PROJECTION specification contained within the text presented as a WKT definition specified an unsupported projection (Krovak (EPSG OP 19952)). None of the Mentor flavors could parse the specified OGC WKT. Exception occurred in method MgCoordinateSystem.MgCoordinateSystem at line 76 in file c:\build_tux_area\mgdev\common\service\coordinatesystem\CoordinateSystem.cpp
Dekuju moc za pomoc!!
I.
binter Zobrazit panel
Arkance Systems - Autorizovaný dealer Autodesk
Arkance Systems
Přihlášen: 13.kvě.2005
AutoCAD Map, AutoCAD 360
Bodů: 31
Přímý odkaz na tuto zprávu Zasláno: 05.bře.2007 v 14:23
bohužel nevím jak jste ze systému dostal tuto hlášku, proto Vám ani nemohu poradit. Ale zeptám se ještě jinak - skutečně potřebujete JTSK? Používáte více souřadných systémů? Pokud pracujete jen s JTSK doporučuji přidržet se obecného XY systému.
S pozdravem Jan Binter
Civil 3D 2009
Bodů: 116
Přímý odkaz na tuto zprávu Zasláno: 05.bře.2007 v 14:56
v oracle 10.2 jsem vytvorila datastore se souradnym systemem S-JTSK, exportovala jsem data do SHP, pak do Oracle a pak jsem s nimi pracovala v Map 3D.
Kdyz jsem chtela v MapGuide Studiu vytvorit layer z data resource, Oracle mi pri preview vrstvy hodi danou hlasku:(
myslite, ze pracovani bez souradnych systemu mi pomuze?
Arkance Systems
Bodů: 31
Přímý odkaz na tuto zprávu Zasláno: 05.bře.2007 v 15:15
Upřímně řečeno jsem z vašeho postupu dosti zmaten. Asi není důležité jak jste postupovala jako to v jakém stavu se nacházíte.
V Oracel máte zdroj FDO, tedy schéma vytvořené Mapem nebo se připojujete k Oraclu jako k externímu FDO zdroji - tedy schématu, jež vzniklo jinak? Pokud je to ten první případ (předpokládám), pak vás určitě zachrání práce s obecným XY systémem.
Civil 3D 2009
Bodů: 116
Přímý odkaz na tuto zprávu Zasláno: 05.bře.2007 v 15:20
super, dik moc...jsem zacatecnik, takze asi spoustu veci delam spatne a neohrabane...presto, jeste jednou dekuji, zkusim ty souradnice...
pekny den
Civil 3D 2009
Bodů: 116
Přímý odkaz na tuto zprávu Zasláno: 06.bře.2007 v 09:16
Mam jeste jeden dotaz, zda se Vam podarilo rozbehat MapGuide s daty v Oracle 10.2...zkousel jste to nekdy?
Arkance Systems
Bodů: 31
Přímý odkaz na tuto zprávu Zasláno: 06.bře.2007 v 09:27
Jistě, to nám tady chodí bez problémů na různých datech i různých MapGuidech včetně Enterprise, který asi máte na mysli.
A vám se to nakonec podařilo nebo potřebujete nějakou pomoc?
Tip 10527:VIPChyba "Windows Installer" při instalaci AutoCAD LT 2016 pod Win10.
Tip 8079:VIPUnhandled exception při spuštění Autodesk Simulation 2012.
Tip 5366:VIPJak zvýšit výkon renderingu v Revitu?
Tip 4256:VIPChyba 1935 (MSXML2) při instalaci AutoCADu.
Tip 10504:VIPChyba 1635 při instalaci Service Packu.
Tip 7345:VIPPrázdný nebo poškozený dialog nastavení uchopování (osnap settings) v AutoCAD Architecture.
Stránka byla vygenerována za 0,445 sekund.
