Using: AutoCAD2012 Status: Offline
Posted: 24.Sep.2014 at 16:03
Hello,
I am trying to create linetypes for fire rated walls. I have created a custom shape and then created a line type using it. However, I would like the linework between the shape to be able to be adjusted with global width similar to how the AutoCAD standard centerline works. If I simply add line work as part of the shape it does not adjust with global width. I have attached a file showing what I have made so far and also showing how I would like the new linetype to appear. Any suggestions would be much appreciated.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum
