Discussion forum
CAD discussion |
Switching between different CAD applications |
Post Reply |
Author | |
Greeno
Newbie Joined: 13.Jan.2010 Location: Fiji Status: Offline Points: 1 |
Topic: Switching between different CAD applications Posted: 06.Oct.2010 at 02:31 |
Is it possible to switch between the different CAD applications...eg..from Civil to architectural/mechanical etc..after CAD is already installed and activated...These options are available while activating the product but is it possible to switch later after that...
Thanks...
T..
Vladimir Michl
Moderator Group Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2018 |
Posted: 06.Oct.2010 at 08:12 |
Do you mean changing the capabilities of a single product or switching between multiple installed products? Switching between multiple versions of AutoCAD is simple (separate icons). Changing e.g. from Architecture to Civil3D is not possible - these are separate products with different order numbers, different installers and different prices. You would need to buy a cross-upgrade.
Vladimir Michl (moderator)
Arkance Systems - arkance-systems.cz - Autodesk reseller |
Post Reply | |
Tweet
This page was generated in 0,336 seconds.
