Discussion forum
CAD discussion |
Set *FREEORBIT* as default rotation? |
Post Reply | Page 12> |
Author | |
tulip3D
Senior Member Joined: 23.Jul.2009 Location: United States Using: AutoCAD2011, Inventor2011 Status: Offline Points: 427 |
Topic: Set *FREEORBIT* as default rotation? Posted: 07.Dec.2010 at 19:54 |
In ACAD 2011, how can I set *FREEORBIT* (similar to Inventor) as my default?
Currently, the default is *ORBIT*, and I hate it, I constantly change it- I'm an Inventor junkie forced to use ACAD 3D |
tulip3D
Posted: 08.Dec.2010 at 13:51 |
C'mon guys!! NOBODY knows squat?? That cant be!
Vladimir Michl
Moderator Group Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2018 |
Posted: 08.Dec.2010 at 13:58 |
Press "2", or press Shift, or right-click and select Free orbit.
Vladimir Michl (moderator)
Arkance Systems - arkance-systems.cz - Autodesk reseller |
tulip3D
Posted: 08.Dec.2010 at 17:38 |
And that will PERMANENTLY change the default? Figured it was some sort of system setting option...
tulip3D
Posted: 09.Dec.2010 at 19:11 |
Nope, that did not do anything. Still reverts to *ORBIT*.
*2* is an unknown command. *SHIFT* + select free orbit doesnt work either. My right click is set to repeat last command. |
edwinprakoso
Groupie Joined: 23.Nov.2010 Location: Indonesia Using: AutoCAD 2016 Status: Offline Points: 64 |
Posted: 10.Dec.2010 at 09:13 |
You can use ctrl + shift + mid button of your mouse.
Or do you want to assign it to other button? You need to do it by modifying CUI.
Rikky
Groupie Joined: 30.Jul.2010 Using: 2004 2006 2007 2009 Status: Offline Points: 56 |
Posted: 10.Dec.2010 at 10:05 |
I have tryed to modify the CUI But he don't accept the changes... So I don't think it is possible to modify it by the CUI.... But is it so hard just to press 2?
tulip3D
Posted: 10.Dec.2010 at 18:15 |
No no no, you guys im trying to set *freeorbit* as my DEFAULT 3D rotation tool.
No shift key, no pressing 2, nothing. And YES, it DOES suck that bad...if your used to full function 3D platform such as Inventor or SolidWorks, instead of autocad's 3D hackjob ;) |
edwinprakoso
Posted: 10.Dec.2010 at 23:35 |
And how you want to activate your 3d rotation tool? By pressing F4 then click your mouse?
tulip3D
Posted: 13.Dec.2010 at 16:14 |
If anyone wants to comment on ANY post in ANY forum, it would be wise to read the FIRST post, and then all the COMMENTS that follow...
Tweet
This page was generated in 0,594 seconds.
