CZ | EN | DE
Login or
registration
  Visitors: 5864
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedHelp with this Design
 Post Reply Post Reply Page  12>
Author
JGrindle21 View Drop Down
Newbie
Newbie
Using: AutoCAD2015
Status: Offline
Direct Link To This Post Topic: Help with this Design
    Posted: 13.Mar.2015 at 15:04
I have been asked to create this design but I have no idea where to start or even what it would look like. Is there anybody that could help me as It would be very much appreciated.
Thanks
A golf professional and caddies workshop is to be designed using sustainable materials. The designers have chosen a framed building with a curved roof. The roof is supported by timber purlins with cross section 300 mm x 50mm at 600mm centre to centre (C/C) resting on 11 glulam arches, spaced at 5500 mm C/C with a span of 28m and a height of 9m. The cross section of each beam is 800mm by 200mm. The roof structure is then supported by 3m high steel columns UC 305x305x283 fixed to a RC rafter slab.
a) Plot a plan view of the roof system consisting of the arches and purlins including axes and distances.
b) Plot a front view of the frame showing the height and the span of the members. Show the cross sections of the arch and the supporting columns with all dimensions.
c) Plot a detail of the connection between the column and the foundation assuming that the column is welded to a steel plate held by bolts to the foundation.
Back to Top
Robert_D View Drop Down
Senior Member
Senior Member
Using: BricsCAD v21, AutoCAD2006
Status: Offline
Direct Link To This Post Posted: 13.Mar.2015 at 19:38
What is your level of CAD experience?
You have enough info to start, however:
"RC Rafter Slab"? Did you mean "Raft Slab"?
No plate supporting arch rafters?
No found. details?
I assume this is not a const. project, but rather an exercise?
Back to Top
Newbie
Newbie
Using: AutoCAD2015
Status: Offline
Direct Link To This Post Posted: 13.Mar.2015 at 20:59
Thanks for replying,
The brief that we were given is exactly the same as I have put in my first post. I'm a first year civil engineering student so I only have basic knowledge, it should be better but I have had to learn how to use it myself as our lecturerer has no idea how to use it.
We only have to make the design as you have said.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 14.Mar.2015 at 00:03
I hope you are doing this in 3D then extracting the 2D views from the 3D model.
Edited by John Connor - 14.Mar.2015 at 00:05
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: AutoCAD2015
Status: Offline
Direct Link To This Post Posted: 14.Mar.2015 at 00:15
Is that the best way to do it?
I haven't started on it yet because I don't know where to begin or what it should look like.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 14.Mar.2015 at 12:18
I guess we're doing this in 2D.  Start with the plan view of the roof.  Layout the arches and purlins.
Re: Raft slab.  Click on the link below for a good explanation of what a raft slab is and how one is constructed.
https://www.cornellengineers.com.au/what-is-a-raft-slab/
Re: curved roof.  I am assuming this is a "barrel vault" roof.  Are you familiar with this type of construction?
Edited by John Connor - 14.Mar.2015 at 12:44
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: AutoCAD2015
Status: Offline
Direct Link To This Post Posted: 14.Mar.2015 at 12:34
Yes I'm fairly comfortable with the terminology.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 14.Mar.2015 at 12:45
Well then, what are you waiting for?  Start with laying out the centerlines of your eleven main arches then move on to laying out your purlin centerlines.  This should not take very long.
Edited by John Connor - 14.Mar.2015 at 13:23
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 16.Mar.2015 at 10:32
Can we get an update on how your design is coming along?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: AutoCAD2015
Status: Offline
Direct Link To This Post Posted: 16.Mar.2015 at 12:58
Sorry i was away for most of the weekend, i've just started this morning. Ive done all of the arches but not sure which way up the purlins go, and how many of them i need?
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,520 seconds.
