CZ | EN | DE
Login or
registration
  Visitors: 9630
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic Closedcopy and insert, write and make BLOCKS
 Post Reply Post Reply
Author
ahmad.albanna View Drop Down
Newbie
Newbie
Using: autocad 2008
Status: Offline
Direct Link To This Post Topic: copy and insert, write and make BLOCKS
    Posted: 20.Oct.2014 at 08:39
Hi
what and why there is a deference between copy a block and insert a block in scale size?
the copy order make the block perfect size.
the insert order make it smaller.
thank you
Regarding
ID.Ahmad albanna
Better Change
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 20.Oct.2014 at 11:28
Hello ahmad.albanna, if you copy a block in the same file there is no problem.
If you copy/paste or insert a block or a file you should check if the "insertion scale" is OK in the 2 files.
You have this in UNITS.
If you set correctly the units in all yours files there shouldn't be any problems working with different units and you should insert other units files without having to scale them after.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 20.Oct.2014 at 11:47
Check the system variable INSUNITS.
Read this first....http://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-Core/files/GUID-A58A87BB-482B-4042-A00A-EEF55A2B4FD8-htm.html
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 20.Oct.2014 at 13:00
Hello John and ahmad, INSUNITS and openning UNITS + seting "drag-and-drop scale" is the same.
When you launch INSUNITS you will have to know what number to apply.
When you launch UNITS you have the seting with its meaning.
No problems for me.
Edited by philippe JOSEPH - 20.Oct.2014 at 15:30
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 20.Oct.2014 at 13:11
JUST FOR FUN !
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,313 seconds.
