CZ | EN | DE
Login or
registration
  Visitors: 13381
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedNeed some basic quick help
 Post Reply Post Reply
Author
gsson View Drop Down
Newbie
Newbie
Using: AutoCAD2015 trial
Status: Offline
Direct Link To This Post Topic: Need some basic quick help
    Posted: 25.Feb.2015 at 16:38
Hello all!
Im new to this forum and maybe and hopefully (in some way) I'll visit this site more often in the future! I have used different CAD-softwares throughout my educations (started when i was around 16 years old). I want to freshen up my skills (got a job interview coming up, should have started earlier though) with the AutoCAD so Ive downloaded the a trial version of the AutoCAD and doing some basic tutorial stuff.
For some reason in the middle of my work the option to offset multiple objects disappeard and I can't really figure out how to get it back?? I appreciate the help, and I guess I'm missing something obvious here Tongue
Appreciate all the response I get! Have a nice day
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 25.Feb.2015 at 16:52
to explain it further, I've only got the Exit and Undo option when I'm going to select the object I want to offset, just recently the Multiple option existed, now it disappeard and I cant find any solution to it. Usually I find a solution myself or I just google the problem but I dont get any hits on the specific problem.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 25.Feb.2015 at 17:17
Interesting.  I just got back to my CAD workstation so I'll have to do some checking first.
How are you invoking the command?
Meanwhile, have you tried closing down AutoCAD and restarting it?  Maybe it's a momentary glitch.
Something else you can try is resetting your Workspace from one type to the other than back.
BTW...the Multiple option is for multiple offsets for one object not multiple offsets for more than one object.
Edited by John Connor - 25.Feb.2015 at 17:33
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 25.Feb.2015 at 17:33
Hi there John, greatly appreciated that you take your time to respond!
I use the command "of", I've also used the tool by accessing it through the ribbon area (click the icon), if that was your question? From there I just follow the basic command line...
I used the offset a couple of time and I acknowledged the M between Exit and Undo.... a meanwhile after when I had to offset multiple objects I noticed it was gone? I guess I have changed some settings in some way, but I cant really figure out what has to do with the offset settings?
Yes, that was my immedite thought after I've pulled some hairs for a couple of minutes, I restarted the the program and I was sure it would be back to normal! I'm sorry if I formulated my english in some wierd fashion it's not native.
Thank you for your response again, greatly appreciated Smile
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 25.Feb.2015 at 17:39
Oh, I knew I would feel stupid in some way after this....
It was some time ago I worked with this software, got some things mixed up it seems. Well, still confusing why the multiple option disappeard
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 25.Feb.2015 at 17:55
Did you try either of my suggestions or was I just whistling in the wind to myself?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 25.Feb.2015 at 21:34
Im sorry if you think you'r talking to deaf ear, you are not and im thankful for your help! As I said Ive tried a couple of The things you mentioned, the last one i missed however and I've been away all evening and still am. Writing on a cell right now. I will come back tomorrow, thank you for your time again.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 25.Feb.2015 at 23:43
Have you customized AutoCAD at all or are you pretty much running it straight as it came out of the box?
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,426 seconds.
