CAD Forum - Database of tips, tricks and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
  Visitors: 9140
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedHelp - Box ang Region
 Post Reply Post Reply
Author
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Topic: Help - Box ang Region
    Posted: 30.Aug.2015 at 12:35
Well without a copy of the drawing it would be difficult to figure out what exactly is going on.  Upload a copy or make it available via Dropbox.  Someone here will take a look at it.
Maybe some of the lines were drawn using a different UCS.
Edited by John Connor - 30.Aug.2015 at 12:35
<<AutoCAD 2015>>
Back to Top
Proladon View Drop Down
Newbie
Newbie
Using: work
Status: Offline
Direct Link To This Post Posted: 30.Aug.2015 at 12:23
coplanar . i confirm lines r on the same elevation (in video u can see
disappearing box . nope,all my layer is turn on
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 29.Aug.2015 at 14:03
Re: coplanar.  Means the lines must have the same elevation.
Re: disappearing box.  Are you drawing it on a layer that has been turned off?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: work
Status: Offline
Direct Link To This Post Posted: 29.Aug.2015 at 05:22
i
 have some problem....
1. i can't use the "Box"
when i set the length and width it will disappear
or whet i type "box" and click the the second dot it will disappear too....
2. sometime can't region
it will said "Open objects must be coplanar"
i have no idea ....
there is video
Edited by Proladon - 29.Aug.2015 at 05:38
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,402 seconds.
