CZ | EN | DE
Login or
registration
  Visitors: 5398
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedBasic Dimensions and Spacing
 Post Reply Post Reply
Author
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Topic: Basic Dimensions and Spacing
    Posted: 14.Jul.2016 at 12:10
Is there no way to use the Solidworks method of randomly placing them, and then dimensioning them afterwards?
Using plain AutoCAD the answer is "no".  You could however do it using Fusion 360.
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 11.Jul.2016 at 13:28
Hello passman86, if you were happy with your Solidworks then I'm afraid you won't be happy with AutoCAD unless you use parametric constrain ( only available in 2D ).
When you use parametric constrain you won't get the good messages to know if you are or not "over constrained".
Maybe Inventor is your answer.
On the other hand if you know where to go AutoCAD will be enough.
Hope this is not a bad answer for you but I'm using ( now ) AutoCAD for methods not for conception.
Back to Top
passman86 View Drop Down
Newbie
Newbie
Using: AutoCAD2013, Solidworks 2016
Status: Offline
Direct Link To This Post Posted: 11.Jul.2016 at 11:14
Hi There Folks,
I have just registered on here as I have come back to AutoCAD after many years away. Last time I used it it was on AutoCAD 1997 and R14. Since then I have mainly used Solidworks through my university and subsequent work positions.
I have just changed jobs and I am now back in the world of 2D drawings, using AutoCAD 2013. I have remembered a decent amount of stuff, enough to get me through the drawings that I am currently working on. But I have one simple question that will make me look like a bit if a dunce to all of you experts.
In Solidworks, I was able to draw a random box or circle and then dimension it to the size I wanted after I had already placed the shape. I know I can dimension the size of these shapes as I draw them in AutoCAD, so that's OK. But my question comes when I want to add the positions of these items relative to other parts of the drawing. For example, if I am drawing a simple fixing plate with 4 holes, at the moment I am offsetting the outer edges of the plate to get the positions of the hole centres and then drawing the holes on top of these. Is there no way to use the Solidworks method of randomly placing them, and then dimensioning them afterwards? Another is, I was drawing some armco barriers around the edge of a building. I drew the basic outline, but didn't draw it in position. I was hoping I could dimension the barrier to the edge of the building outline I had already done, but the only dimensions I used simply stated the distance they were away, and it did not let me modify the size to what I wanted.
At the moment, I am simply offsetting from items I have already drawn and then using the Trim/Extend functions to get what I need. To me, this feels like I am doing it the long winded way, but it just may be that I am too used to the Solidworks way of doing things.
Sorry if this makes no sense.
Edited by passman86 - 11.Jul.2016 at 11:15
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,434 seconds.
