Discussion forum
CAD discussion |
AutoCAD 2012 - Commands not working |
Post Reply |
Author | |
SAMLERMAN
Newbie Joined: 22.Aug.2016 Location: United States Using: AutoCAD2012 AutoCAD2016, Revit2016 Status: Offline Points: 16 |
Topic: AutoCAD 2012 - Commands not working Posted: 13.Sep.2016 at 20:47 |
Hello,
In last 2 days some AutoCAD commands disappeared-DDATE, UNITS (Unknown command "UNITS"). Anybody know what can be the problem? Thank you
SAMLERMAN
Posted: 13.Sep.2016 at 21:20 |
I just realize that also REFEDIT and XOPEN not working...
John Connor
Senior Member Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 14.Sep.2016 at 00:25 |
Did you recently download and use any custom lisp routines?
Did you try a REPAIR of the installation? Note that a REPAIR is not the same as an Uninstall/Reinstall. |
<<AutoCAD 2015>> |
SAMLERMAN
Posted: 14.Sep.2016 at 01:30 |
I did write one lisp routine, nothing to do with these commands, I already unloaded it, doesn't help. I will try the REPAIR tomorrow. Thank you
Vladimir Michl
Moderator Group Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2018 |
Posted: 14.Sep.2016 at 08:04 |
Is it an English version of AutoCAD? Plain AutoCAD, not e.g. Civil 3D?
Try the dotted version of the command ".UNITS". There could be also a problém with the Registry settings - this would need a repair installation.
Vladimir Michl (moderator)
Arkance Systems - arkance-systems.cz - Autodesk reseller |
SAMLERMAN
Posted: 14.Sep.2016 at 16:52 |
Yes Vladimir, it's plain English version.
But I resolved it by REPAIR. Thank you all!
John Connor
Posted: 14.Sep.2016 at 17:33 |
Good to hear and thanks for the update.
<<AutoCAD 2015>> |
cloudsyntrix
Newbie Joined: 19.Sep.2016 Location: United States Using: IronCAD Status: Offline Points: 1 |
Posted: 19.Sep.2016 at 06:10 |
Thank you for sharing.
http://cloudsyntrix.com/ - catalyst switches cisco in new york
Post Reply | |
Tweet
This page was generated in 0,342 seconds.
