Please abide by the
rules of this forum.
Author |
Topic Search Topic Options
kined
Newbie
Using: autocad2013
Status: Offline
Topic: DWG to PDF with pictures and hyperlink Posted: 18.Oct.2016 at 10:59 |
Hi, When I converted a dwg to pdf (with pdfmaker in autocad) I lose the picture. I did a lot of testing and nothing works.(Reduce the image quality etc.)
Only when I use "export" in pdf I RECOVERED my picture but I lost my hyperlinks. I need in my final PDF , layer, hyperlink and pictures. Can you help me ? thanks
John Connor
Senior Member
Using: AutoCAD 2018
Status: Offline
Posted: 18.Oct.2016 at 11:24 |
PDF's were never meant to be a substitute for a .dwg file and our dependence on them is questionable at best.
<<AutoCAD 2015>>
kined
Newbie
Using: autocad2013
Status: Offline
Posted: 18.Oct.2016 at 11:36 |
thank you for your participation, but I am forced to usePDFIt is used for making available plans for common users in an archiving system. This archiving system to use only the PDF as viewformat (system used by all the group across europe). Everything worked fine with my old PC with Windows XP.
rebellio
Senior Member
Using: Autocad 2018
Status: Offline
Posted: 18.Oct.2016 at 12:23 |
John Connor
Senior Member
Using: AutoCAD 2018
Status: Offline
Posted: 18.Oct.2016 at 12:31 |
kined wrote:
Everything worked fine with my old PC with Windows XP. |
So you are implying the problem isn't with AutoCAD but with the OS you are running? That doesn't make much sense.
<<AutoCAD 2015>>
kined
Newbie
Using: autocad2013
Status: Offline
Posted: 18.Oct.2016 at 12:53 |
I'm not a computer engineer, just a common user of software, but the OS is a data that could explain it. I used Acrobat pro and AutoCAD 2010 on XP, and now with windows 7 is acrobat DC and autocad 2014. In any case it should work !! either XP or windows 7 !!
John Connor
Senior Member
Using: AutoCAD 2018
Status: Offline
Posted: 18.Oct.2016 at 12:55 |
But you also have another variable (i.e. - the version of Acrobat being used) do you not?
Edited by John Connor - 18.Oct.2016 at 12:55
<<AutoCAD 2015>>
kined
Newbie
Using: autocad2013
Status: Offline
Posted: 18.Oct.2016 at 13:07 |
< name="" id="" ="" size="40"> Yes indeed. I just unfortunately not go back. software is imposed by management on a national level. I am forced to use DC and AutoCAD 2014. Yes indeed. I just unfortunately not go back. software is imposed by management on a national level. I am forced to use DC and AutoCAD 2014. I'm going to leave my question on the autodesk official forum. perhaps can it better target the problem.
Edited by kined - 18.Oct.2016 at 13:08
kined
Newbie
Using: autocad2013
Status: Offline
Posted: 18.Oct.2016 at 13:09 |
thx Rebellio I have tried but it's the same , no picture
Edited by kined - 18.Oct.2016 at 13:09
John Connor
Senior Member
Using: AutoCAD 2018
Status: Offline
Posted: 18.Oct.2016 at 13:23 |
Well I just ran a test creating a PDF from within AutoCAD of a drawing that contains a picture and a hyperlink to an Excel spreadsheet. When the PDF opened the picture was there and the hyperlink worked. I'm running AutoCAD 2017 on a computer that uses Windows 7 Pro as the OS. So, one of two things is happening. Either you are doing something wrong and don't realize it or the problem lies with Acrobat. The problem isn't AutoCAD or the OS.
Edited by John Connor - 18.Oct.2016 at 13:24
<<AutoCAD 2015>>
