Discussion forum
CAD discussion |
AutoCAD 3D model |
Post Reply |
Author | |
philippe JOSEPH
Senior Member Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1428 |
Topic: AutoCAD 3D model Posted: 15.Dec.2016 at 07:34 |
Hello Al4n_rdz, when in AutoCAD launch the command LIST on one of your 3D objects and get the answer of what the entity is.
If it's a 3D "volumic" object the answer should be : 3DSOLID If it's a 3D wireframe or an other thing the answer should be 3DFACES or 3DMESH On the other hand I think that you can dimension 3D wireframe directly in 3D. Please tell me ( us ) your method to generate your views ( on AutoCAD ). "essayons" non, instead let us try and succeed.
Edited by philippe JOSEPH - 15.Dec.2016 at 07:45 |
John Connor
Senior Member Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 14.Dec.2016 at 23:25 |
The question was, "How can I check if my model is a mesh?" Do you have an answer or are you just here to talk about how much you like mesh models?
<<AutoCAD 2015>> |
Mercediz
Newbie Joined: 14.Dec.2016 Location: United States Using: 2015 Status: Offline Points: 3 |
Posted: 14.Dec.2016 at 21:02 |
I like such models, I used it in many projects...
I hate to envy other people
Al4n_rdz
Newbie Joined: 14.Dec.2016 Location: Mexico Using: AutoCad 2017, Advance Steel 2017 Status: Offline Points: 3 |
Posted: 14.Dec.2016 at 20:39 |
Thanks for your answer and maybe it's very obvious or it sounds very silly my question, but I'm not very familiar with the program, how can i check if my model is a mesh? ..
"Essayons"
Vladimir Michl
Posted: 14.Dec.2016 at 20:11 |
If your model is a 3D mesh, there is a chance to convert it to a solid. But if it is only a wireframe, there is no automated way.
Vladimir Michl (moderator)
Al4n_rdz
Posted: 14.Dec.2016 at 19:55 |
Hello, I'm new to the
forum, I'm a student and I take this opportunity to greet you and ask you my
questions and see if anyone can help me solve it, the question is: I really hope someone can help me and thank you for your time. Edited by Al4n_rdz - 14.Dec.2016 at 20:05 |
"Essayons"
Post Reply | |
Tweet
This page was generated in 0,392 seconds.
