Discussion forum
CAD discussion |
3DPlot Utility |
Post Reply |
Author | |
Vladimir Michl
Topic: 3DPlot Utility Posted: 02.Feb.2017 at 14:13 |
It depends on what the max. value should be - probably just 0.5.
Due to the meshing algorithm used it is currently not possible to completely skip/omit nodes.
Vladimir Michl (moderator)
chaitu1351
Newbie Joined: 02.Feb.2017 Location: India Using: AutoCAD 2017 Status: Offline Points: 3 |
Posted: 02.Feb.2017 at 07:59 |
Thanks for your suggestion.
your answer solves half of the problem What should write in place of '?' (upper limit of y) in 3Dplot code (3Dplot z 0.1 0.5 0.01 0.1 '?' 0.01) Should I have to replace it by 2*(0.5) (ie., 2*max of x)? Also in your solution, The values that are greater than 2*x become same points And I think it might change the curvature. Is there an option to not to consider those points Thank you
Vladimir Michl
Posted: 02.Feb.2017 at 07:43 |
If I understand this correctly, you can just modify your Z function so as Y does not go over 2*X. E.g. this way:
(defun Z (x y) (list x (min y (* 2.0 x)) (+ x (min y (* 2.0 x))))) |
chaitu1351
Posted: 02.Feb.2017 at 07:14 |
I am using 3DPlot Utility for Surface Generation.
In my case, the y upper limit is a function is current x value. Can anyone help solve this problem? There is an simple form of my problem 0.1 < x < 0.5 0.1 < y < 2*x (defun z (x y) (list x y (+ x y))) How should write the code for 3D plot (3Dplot z 0.1 0.5 0.01 0.1 '?' 0.01) Thank you
Post Reply | |
Tweet
This page was generated in 0,321 seconds.
