Discussion forum
CAD discussion |
Question Surface face normal direction |
Post Reply | Page 12> |
Author | |
HaiderOfSweden
Newbie Joined: 18.Oct.2011 Location: Sweden Using: Revit, AutoCAD, 3dsMax, Rhino Status: Offline Points: 12 |
Topic: Question Surface face normal direction Posted: 18.Feb.2017 at 14:19 |
Hi!
I link AutoCAD stuff in 3dsMax on daily basis. The models are created in AutoCAD and rendered in Max. Sometimes, the linked mesh has its faces oriented in the wrong direction. In 3dsMax, there is a modifier called Normals that lets you Flip all normals or Unify them. How do I flip the normal direction? For reference, in Rhino (which also is a CAD software) there is a command called DIR (http://docs.mcneel.com/rhino/5/help/en-us/commands/dir.htm) |
Vladimir Michl
Moderator Group Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2018 |
Posted: 20.Feb.2017 at 13:07 |
There is a FlipFace utility for AutoCAD - see:
and
Vladimir Michl (moderator)
Arkance Systems - arkance-systems.cz - Autodesk reseller |
HaiderOfSweden
Posted: 23.Feb.2017 at 14:03 |
Thank you Vladimir!
I tried this on polygon meshes and it works just the way I asked. However, the issue I have is on solids/surfaces, so how can I use it here? The command seems only to work on 3d faces.
John Connor
Senior Member Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 23.Feb.2017 at 14:52 |
I think this can be accomplished in Inventor. Search on "reverse normal direction of translated face or body" for further information.
<<AutoCAD 2015>> |
HaiderOfSweden
Posted: 23.Feb.2017 at 15:37 |
Thanks. We don't have Inventor at the office just now, but maybe at some point. If it opens and saves DWG natively, this would be a acceptable detour to fix and then save and continue in AutoCAD. Otherwise, I could as well use 3dsMax to fix the normals, and re-export. But I'll wait to hear if someone hopefully knows an AutoCAD way for solids/surfaces similar to the first suggestion that was for 3d faces.
Vladimir Michl
Posted: 24.Feb.2017 at 09:11 |
You can explode more complex objects to 3D faces.
HaiderOfSweden
Posted: 24.Feb.2017 at 10:41 |
Please have a look at this DWG https://www.dropbox.com/s/kv50hyq08zi0ayi/Surfaces.dwg?dl=0 (I don't know how to attach - if someone would please tell me how, I can attach the file here for future reference) Colors: Green: Regular surfaces. Yellow: When I exploded the surfaces, they turned into regions, not 3d faces. Red: The problematic surfaces, ie need their faces to be flipped. I can see that the faces are flipped when I export this to 3dsMax. See if it works for you and thank you in advance.
HaiderOfSweden
Posted: 02.Mar.2017 at 14:09 |
Did anyone have the time to check the attached file?
I didn't manage to explode to a 3D face, it rather turned into something else.
HaiderOfSweden
Posted: 26.Aug.2017 at 23:05 |
In case anyone else stumbles into this matter, I solved it by rebuilding the surfaces.
Planar surface can be exploded and output lines. A surface can be built from them with SURFNETWORK. After exploding the rounded corner, it can be rebuild with Loft with Guide Curves. If we wanted a command similar to Rhinos FLIP, I think it has to be programmed in .NET or similar.
philippe JOSEPH
Senior Member Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1427 |
Posted: 27.Aug.2017 at 21:07 |
Hello HaiderOfSweden, why can't you render ( and other things ) directly with AutoCAD ?
You can render anyway with simple colors even if you don't affect a material to your solids. If you affect a material it can be smarter...
Edited by philippe JOSEPH - 27.Aug.2017 at 21:07 |
Tweet
This page was generated in 0,410 seconds.
