Discussion forum
CAD discussion |
Connect line to a circle |
Post Reply |
Author | |
HarunT
Newbie Joined: 02.Mar.2017 Location: United Kingdom Using: Autocad 2014 Status: Offline Points: 2 |
Topic: Connect line to a circle Posted: 02.Mar.2017 at 16:53 |
uploads/710612/images_1.pdf
Hi there, how can i connect this line to any point on the circle? this is what it looks like when i zoom in. hope you can help.
HT
Vladimir Michl
Moderator Group Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2018 |
Posted: 02.Mar.2017 at 16:59 |
If you use OSNAP, your geometry should be precise - despite it may be displayed disconnected in extreme zoom levels.
Make sure your geometry is not too far from the world origin (0,0,0).
Vladimir Michl (moderator)
Arkance Systems - arkance-systems.cz - Autodesk reseller |
John Connor
Senior Member Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 02.Mar.2017 at 17:08 |
If the line is not connected to a quadrant or tangent to the circle then to connect it to any point on the circle try drawing a temporary line that intersects the circle then use the INTERSECTION osnap to make the connection.
<<AutoCAD 2015>> |
Kent Cooper
Senior Member Joined: 12.Mar.2013 Location: United States Using: AutoCAD2020, 2023 Status: Offline Points: 631 |
Posted: 02.Mar.2017 at 18:58 |
If you used some Osnap mode to put it on the Circle, or Trim or Extend, and if this is Zoomed significantly in since then, it's just a matter of display resolution. REGEN and it will probably meet visually [it really does meet geometrically already]. It's a function of the way curves are segmented in display only. To at least lessen the effect, go into VIEWRES and give it a higher Circle Zoom Percentage.
Post Reply | |
Tweet
This page was generated in 0,488 seconds.
