Discussion forum
CAD discussion |
Linetype Issues |
Post Reply | Page 123> |
Author | |
mik29
Newbie Joined: 15.Mar.2017 Location: United States Using: AutoCAD 2016 Status: Offline Points: 18 |
Topic: Linetype Issues Posted: 15.Mar.2017 at 17:06 |
Hello.
I am working in C3D 2016. I noticed my linetypes were not correct. Our State DOT has standards for linetypes. After I did imported the standards and open the drawing I had some strange lines. I have my LTSCALE =1. MSLTSCALE=1, VSLTSCALE=1 and it has not changed. The biggest problem that only my computer have this issue. I attached pictures of what they look on my computer and on others. Thank you
aanonimnim
Newbie Joined: 03.Jul.2013 Location: Poland Using: autocad Status: Offline Points: 5 |
Posted: 05.Apr.2017 at 01:07 |
Hi,
Is it a line or polyline? Check the thickness of the layer as well. Sometimes the same layers have different standard settings. I know - sound obvious but I catch myself many times on that ;) Kamil www.CADMasters.guru |
John Connor
Senior Member Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 05.Apr.2017 at 11:34 |
aa: Please explain something to me. If I give you a drawing where I have set the lineWEIGHT by layer and you open that drawing on your computer why/how would it appear differently unless you changed it or you had lineweight display enabled/disabled? Additionally, if it is a pline the system variable PLINEWID is saved with the drawing and not in the Windows Registry. How then does it automagically change when opened by another cad tech on a different computer?
Edited by John Connor - 05.Apr.2017 at 12:52 |
<<AutoCAD 2015>> |
John Connor
Posted: 05.Apr.2017 at 12:07 |
mik29: What is VSLTSCALE? When I type that in at the command line I get this:
Command: VSLTSCALE Unknown command "VSLTSCALE". Press F1 for help. Could you have been referring to PSLTSCALE? BTW...is Lineweight Display enabled? Edited by John Connor - 05.Apr.2017 at 12:51 |
<<AutoCAD 2015>> |
mik29
Posted: 05.Apr.2017 at 15:26 |
this is what we're wondering too. Thanks.
mik29
Posted: 05.Apr.2017 at 15:30 |
sorry I mistype. It is PSLTSCALE .Yes Linewight display is enabled.
Thank you.
mik29
Posted: 05.Apr.2017 at 15:34 |
Hello.
It's PLINE.
John Connor
Posted: 05.Apr.2017 at 15:43 |
So what happens if you toggle Lineweight off?
<<AutoCAD 2015>> |
mik29
Posted: 05.Apr.2017 at 15:52 |
Absolutely no changes.
John Connor
Posted: 05.Apr.2017 at 16:30 |
Do you utilize custom lisp routines that automatically load?
<<AutoCAD 2015>> |
Tweet
This page was generated in 0,354 seconds.
