CAD Forum - Database of tips, tricks and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
  Visitors: 3175
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedFast layer change to current layer?
 Post Reply Post Reply Page  12>
Author
slupi View Drop Down
Newbie
Newbie
Using: AutoCAD2014
Status: Offline
Direct Link To This Post Topic: Fast layer change to current layer?
    Posted: 02.Aug.2017 at 13:24
Hello,
I want to change the layer of different fresh inserted blocks to the current layer.
Is there a fast way to do this? (command?)
I don´t want to klick on the dropdown and look for the right layer all the time...Dead
BR.
Thomas
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 02.Aug.2017 at 14:36
Are these blocks that are used often?  If so, would they normally be inserted on the same layer each time and in each drawing?
Another option is to use the Make Layer current command by clicking on the appropriate icon on your Ribbon.
Edited by John Connor - 02.Aug.2017 at 14:48
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: AutoCAD2014
Status: Offline
Direct Link To This Post Posted: 02.Aug.2017 at 15:00
Yes they are used very often, but always on different layers.
About 60 different Blocks
for exampel:
i have to place 100 tables on layer_+0000
20 tables on layer_+3500
6 tables and 5 chairs on layer_+6500
and i want just to activate the layer_+6500 as current one and place 6 tables and 5 chairs out of the library into the layout select them and change their layer to the current one.
without klicking an the dropdown an searching for the right layer.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 02.Aug.2017 at 15:02
I suggested a second option.  There is no clicking on a dropdown and searching for the right layer.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: AutoCAD2014
Status: Offline
Direct Link To This Post Posted: 02.Aug.2017 at 15:20
How does it work?
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 02.Aug.2017 at 15:34
You click on the icon, the command is invoked, then you pick an object on the layer you want to make current.  Not difficult at all.
Edited by John Connor - 02.Aug.2017 at 15:36
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: AutoCAD2014
Status: Offline
Direct Link To This Post Posted: 02.Aug.2017 at 15:50
haven´t used this toolbox before!
Thanks a lot.
Edited by slupi - 02.Aug.2017 at 15:51
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 02.Aug.2017 at 16:16
It's not a toolbox or a toolbar.  It's merely a command found on the Ribbon > Layers panel.
<<AutoCAD 2015>>
Back to Top
Kent Cooper View Drop Down
Senior Member
Senior Member
Using: AutoCAD2020, 2023
Status: Offline
Direct Link To This Post Posted: 04.Aug.2017 at 22:37
Originally posted by slupi slupi wrote:
Hello,
Am I correct that some messages here are not about what you're really asking?  They are about changing the current Layer to that of some selected object, whereas the quoted sentence sounds like you want to go the other direction - change selected object(s) so that they will be on the current Layer.
This is what I use to do that:
;; ToCurrentLayer.lsp [command name: TCL]
;; Moves selected objects to current layer.
(defun C:TCL ()
  (command
    "_.select" pause
    "_.chprop" "_previous" "" "_layer" (getvar 'clayer) ""
  ); end command
); end defun
Back to Top
Nate143 View Drop Down
Newbie
Newbie
Using: AutoCAD 2018, Revit 2018, Inventor 2018
Status: Offline
Direct Link To This Post Posted: 10.Aug.2017 at 07:40
If you're using the blocks why not just edit them to always com in on the layer that you want them to come in on?
or am I understanding the question incorrectly?
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,409 seconds.
