Discussion forum
Gizmo Axis Grips do nothing |
Post Reply ![]() |
Author | |
MatthewG ![]() Newbie ![]() Joined: 10.Oct.2017 Location: United States Using: Acad 2018 Status: Offline Points: 3 |
![]() ![]() ![]() ![]() ![]() Posted: 03.Jan.2018 at 16:55 |
hoping this is a simple solution....
Using AutoCAD Civil 3D on Windows 7 Ult. AMD processor and NVidea GeoForce GTS450 In both 2D and 3D, when I select and object, the correct (move, rotate, scale) Gizmo appears like always, but the Axis Arrows do nothing now. I used to be able to click and move or manipulate using these Axis Arrows. They just suddenly stopped working. Help!
John Connor ![]() Senior Member ![]() Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 6838 |
What steps have you taken to troubleshoot the problem before posting here?
<<AutoCAD 2015>> |
After 2 solid days of hunting and testing....I finally found this worked...
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-reset-AutoCAD-to-defaults.html no joke.....I just found this, right after posting the problem here. No idea what variable was reset and fixed it, but it worked.
Edited by MatthewG - 03.Jan.2018 at 17:35 |
That would have been near the top of my list of suggestions. Glad to hear your issue was resolved.
<<AutoCAD 2015>> |
Post Reply ![]() |
Tweet
Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,160 seconds.
