CAD Forum - Database of tips, tricks and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
  Visitors: 9253
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedText
 Post Reply Post Reply
Author
Lexville View Drop Down
Groupie
Groupie
Using: Autocad 2015
Status: Offline
Direct Link To This Post Topic: Text
    Posted: 13.Mar.2018 at 01:31
What should be my Text height if my scale in paper space is 1/4"- 1'-0"
ADV
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 13.Mar.2018 at 06:30
Text placed in a layout should be real world size.  Most users will go with either 3/32" or 1/8".
<<AutoCAD 2015>>
Back to Top
philippe JOSEPH View Drop Down
Senior Member
Senior Member
Using: AutoCAD Mechanical 2017
Status: Offline
Direct Link To This Post Posted: 13.Mar.2018 at 07:43
Hello Lexville and John, I would add that on little paper sizes like Ansi "A" and "B" it would be 3/32".
On the others sizes Ansi "C" , "D" and "E" it would be 1/8" for it to be still readable when printed on little paper sizes.
Back to Top
Groupie
Groupie
Using: Autocad 2015
Status: Offline
Direct Link To This Post Posted: 13.Mar.2018 at 18:49
Thanks, so how many inches is 3/32? because I'm doing call out on my drawing on paper space.
ADV
Back to Top
Kent Cooper View Drop Down
Senior Member
Senior Member
Using: AutoCAD2020, 2023
Status: Offline
Direct Link To This Post Posted: 13.Mar.2018 at 18:59
You can divide 3 by 32 [that's all a fraction is] and find out....
Back to Top
Groupie
Groupie
Using: Autocad 2015
Status: Offline
Direct Link To This Post Posted: 13.Mar.2018 at 21:14
Thanks, Where do you usually place the text and dimensions in model space or in layout?
ADV
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 13.Mar.2018 at 21:36
There are pros and cons to each method.  It might be influenced by the type of drawings you are creating.  Our company has over 300 drawings from years past where everything was placed in model space.  We haven't bothered to change them.  Newer drawings have both text and dimensions placed in the layout.
<<AutoCAD 2015>>
Back to Top
TedG View Drop Down
Newbie
Newbie
Using: AutoCAD 2017, Inventor Professional 2017
Status: Offline
Direct Link To This Post Posted: 06.Apr.2018 at 16:45
(this is more for the OP)
3/32" = .1 of an inch (vs 1/8" = .125 of an inch)
To calculate what size it should be in MS, you would simply multiply your intended height by the scale factor.
ie: 1/8" plotted text in a (1/4" = 1'-0") scaled viewport: .125 x48 = 6"
Also a nice trick is to have your desired text in PS and use "chspace" and send it to MS and it calculates it for you.
But maybe you know all this.
Edited by TedG - 06.Apr.2018 at 16:46
AutoCAD 2017, REVIT Structure 2017, Inventor Professional
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,352 seconds.
