CAD Forum - Database of tips, tricks and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
  Visitors: 8734
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic Closedline type
 Post Reply Post Reply Page  12>
Author
waynelem View Drop Down
Groupie
Groupie
Using: autocad 2012 full /2014lt
Status: Offline
Direct Link To This Post Topic: line type
    Posted: 19.Mar.2018 at 22:23
I need to make a custom line type using a 36" o.d. and a 15" i.d. donut. or a filled circle.
I have been trying to first make a shape with the  donut and this does not seem to work.
Also tried to use two circles and a fill, still does not work.
Any ideas?
Thanks
Wayne
wayne
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 19.Mar.2018 at 22:42
How about two circles and an exploded (dense) hatch pattern?
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 19.Mar.2018 at 23:29
Tried that. Did not work.
Next?
wayne
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 20.Mar.2018 at 02:37
Can't believe this is that hard to make happen. It will work if the area is not filled.
wayne
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 20.Mar.2018 at 10:27
Almost there but not quite.  Yeah, the hatch pattern isn't dense as this was just a test.  The problem to solve is getting rid of the spurious little line segments circled in red.  I called mine DonutHoleLT.lin.  The magenta color donut at the top is the shape file.
<<AutoCAD 2015>>
Back to Top
Kent Cooper View Drop Down
Senior Member
Senior Member
Using: AutoCAD2020, 2023
Status: Offline
Direct Link To This Post Posted: 20.Mar.2018 at 17:07
Originally posted by John Connor John Connor wrote:
....  The problem to solve is getting rid of the spurious little line segments circled in red.  ....
I'm afraid that's not a problem that can be solved, it being the nature of anything open-ended drawn with any non-continuous linetype to "fill out the ends," beyond full cycles of the linetype definition, with continuous extensions [in closed objects, it can make adjustments].  You can minimize them by adjusting the length of an object [when that's not made impractical or impossible by other considerations], but you can't get rid of them entirely.
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 20.Mar.2018 at 19:22
How critical is the relationship between the 36" vs. 15" dimensions?  Could you use an embedded-Text linetype instead of an embedded-Shape one?  For example, the 0xA3 character in the Wingdings font looks pretty much just like that (when I make one 36 units wide outside, its inside diameter is about 14-1/2 units), and it's truly solid-filled, so you don't need to fake that part.
Edited by Kent Cooper - 20.Mar.2018 at 19:24
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 21.Mar.2018 at 08:33
Good suggestion Kent.Thumbs Up
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 21.Mar.2018 at 15:39
I only has to be close, give or take a couple of inches.
wayne
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 21.Mar.2018 at 15:46
Then follow Kent's suggestion.
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,344 seconds.
