Discussion forum
CAD discussion |
How to Draw Arc with Known 3 Parameters? |
Post Reply |
Author | |
dery
Senior Member Joined: 31.Jan.2018 Location: United States Using: AutoCAD 2014 Status: Offline Points: 113 |
Post Options
Thanks(0)
Posted: 28.Jan.2024 at 08:07 |
I would like to ask technical drawing question.
How do you draw arc with radius of 400 that pass through point A and tangent to the Red line as shown in attached image? Please show me the step-by-step and its construction geometry. Thank you in advance Edited by dery - 29.Jan.2024 at 01:20 |
dery
Post Options
Thanks(0)
Hi Mr. Philippe Joseph, can you answer my question please?
philippe JOSEPH
Senior Member Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1428 |
Post Options
Thanks(0)
How to draw an arc with three known parameters ?
-1- Offset the red line by 400 on the lower side. -2- Draw a circle of radius 400 centered on the point "A". -3- Draw a circle of radius 400 passing by the intersection between the offseted red line and the circle centered on the point "A". -4- Trim the circle on the red line and the green line and you have got your arc.
Kent Cooper
Senior Member Joined: 12.Mar.2013 Location: United States Using: AutoCAD2020, 2023 Status: Offline Points: 629 |
Post Options
Thanks(0)
... bearing in mind that there are two such Circles, and two resulting Arcs tangent to the red line through point A [unless point A is close enough to an end of the line that one of the tangency points would be off the end].
philippe JOSEPH
Post Options
Thanks(0)
Hello Kent and Dery, I have placed in the CAD/BIM Blocks library my file :
HOW TO DRAW AN ARC-PJH.dwg. I see only one arc but I can be wrong.
dery
Post Options
Thanks(0)
Hi Mr. Joseph, can you create the CAD/BIM block that can be opened in AutoCAD 2014 please? Thanks
Edited by dery - 31.Jan.2024 at 09:37 |
philippe JOSEPH
Post Options
Thanks(0)
It's in the CAD/BIM BLocks : HOW TO DRAW AN ARC-PJH-2014.dwg
dery
Post Options
Thanks(0)
Hi Mr. Joseph. I saw your drawing already. However I still don't understand. How do you obtain those angles? Please advance and explain.
dery
Post Options
Thanks(0)
Hi Mr. Joseph, currently I am at this step (please see attached image). Can you tell me please what should I do for the next step? Thank you so much.
philippe JOSEPH
Post Options
Thanks(0)
Dery, the "step by step" method is in the CAD/BIM Block library.
Post Reply | |
Tweet
This page was generated in 0,639 seconds.
