Discussion forum
CAD discussion |
AutoCAD Blocks - Imperial |
Post Reply |
Author | |
wstowe
Newbie Joined: 30.Jan.2024 Location: United States Using: AutoCAD, Plant 3D Status: Offline Points: 3 |
Post Options
Thanks(0)
Posted: 31.Jan.2024 at 16:22 |
Hello,
I'm trying to find US Imperial blocks but many of the ones I find here are metric. Is there a way to filter for Imperial? I'm specifically looking for 2d house designs blocks such as doors, windows, toilets, cabinets etc. Thank You!
philippe JOSEPH
Senior Member Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1428 |
Post Options
Thanks(0)
I don't know if this will really help you but if you have your files setted with imperial units you can INSERT and not copy/paste files setted with metric units and the blocks will come at scale 1/1, with the good dimensions and with the indication of the metric measures when you read their properties ( Ctrl + 1 ).
wstowe
Post Options
Thanks(0)
Thank you for your response. I will try this when I use one in metric.
Another concern is building materials being different in other contries. I wanted to find some details specifically for the US market so it better matches what I need. One example is wall details using dimesnional lumber instead of concrete block.
Post Reply | |
Tweet
This page was generated in 0,338 seconds.
