Discussion forum
CAD discussion |
center mass |
Post Reply |
Author | |
Vladimir Michl
Topic: center mass Posted: 17.Sep.2009 at 19:12 |
Just use APPLOAD to load the VLX file and run the CENTROID command.
Vladimir Michl (moderator)
albud1962
Newbie Joined: 17.Sep.2009 Status: Offline Points: 1 |
Posted: 17.Sep.2009 at 17:24 |
I downloaded the VLX file. How do I activate the command?
Vladimir Michl
Posted: 29.Jul.2009 at 11:35 |
See also the CENTROID utility (Download) which will actually draw the "center mass" point.
Kajito
Senior Member Joined: 29.Oct.2008 Location: Ireland Status: Offline Points: 130 |
Posted: 29.Jul.2009 at 11:15 |
you need to create region of your area. Than select region/massproperties command and select you object. You'll have listed all the properties like centroid, moment of inertia and so on. Do not forget that everything is related to the chosen 0,0 point (axes), so if you want to have correct props, you need to change 0,0 point into the center of your object.
Vladimir Michl
Posted: 27.Jul.2009 at 09:26 |
See the related tips below your question (generally: with MASSPROP).
aginor86
Newbie Joined: 26.Jul.2009 Location: Greece Status: Offline Points: 1 |
Posted: 26.Jul.2009 at 23:25 |
how i can find the "center mass" point in a aeria???
those who can,do.
those who can not, teach. those who can not teach, admin. |
Post Reply | |
Tweet
This page was generated in 0,313 seconds.
