Discussion forum
CAD discussion |
Xref position |
Post Reply |
Author | |
Vladimir Michl
Topic: Xref position Posted: 22.Feb.2010 at 18:31 |
The Xref Attach function prompts for the reference point (coordinate). This is usually "0,0,0" - unless you have changed the RefPoint in the Xref DWG.
Vladimir Michl (moderator)
nicehasan3k
Newbie Joined: 25.Jan.2010 Location: United Arab Emirates Status: Offline Points: 1 |
Posted: 22.Feb.2010 at 17:28 |
dear all, i would like to know about x-ref file when some times i try to attached its not coming in proper place (as per coordinates) but when i try to copy xref file to main dwg. its coming at exact position, what is the solution?
Edited by nicehasan3k - 22.Feb.2010 at 17:29 |
Thanks & Regards,
HASAN |
Post Reply | |
Tweet
This page was generated in 0,379 seconds.
