Discussion forum
CAD discussion |
How to maintain elements as coplanar |
Post Reply |
Author | |
hdchique
Newbie Joined: 28.Dec.2009 Location: United States Using: AutoCAD2010, MicroStation V8, 2004 Edition Status: Offline Points: 5 |
Topic: How to maintain elements as coplanar Posted: 02.Mar.2010 at 17:37 |
All of my work (process piping) is 2D. I find that, when I xref a civil file, which is 3D, some of my elements spontaneously become non coplanar. I can even rotate & copy an element and the resulting element is not coplanar with the original.
Some commands involving 2 elements do not work when the elements are non coplanar. For instance, you can trim or extend to intersection (strange), but you can't chamfer non coplanar objects.
How do I avoid this phenomenon and how do I fix it when it occurs?
CarlB
Senior Member Joined: 16.Oct.2009 Location: United States Status: Offline Points: 321 |
Posted: 02.Mar.2010 at 18:55 |
To avoid it (to some degree), set "osnapz" to
"0" (I think; verify)
To fix objects that have a z value other than 0, use the "flatten" command.
tulip3D
Senior Member Joined: 23.Jul.2009 Location: United States Using: AutoCAD2011, Inventor2011 Status: Offline Points: 427 |
Posted: 02.Mar.2010 at 20:50 |
"I find that, when I xref a civil file, which is 3D, some of my elements spontaneously become non coplanar"
This might be due to referenced/binded/attached blocks/elements or whatever in that civil file that have different global x,y,z locations coordinates as compared to your current settings. Wish I could offer more but Civil 3D aint my spec-e-ality lol, good luck!
MattMurphy
Newbie Joined: 16.Feb.2010 Location: United States Status: Offline Points: 4 |
Posted: 03.Mar.2010 at 09:54 |
I've had problems before when XRefs don't have their BASE set to 0,0,0. Open the XRef then type BASE and change it to 0,0,0 if necessary. Might help........
--------------------------------------- 3D AutoCAD Pipework - http://www.HerculeDesign.com/ Edited by MattMurphy - 03.Mar.2010 at 09:57 |
deadguy
Newbie Joined: 04.Mar.2010 Status: Offline Points: 3 |
Posted: 04.Mar.2010 at 17:20 |
The quick fix is to select all affected lines, and change their properties in the property window so that Z=0 on the start and end points..
Though you might have to explode them if they're within blocks.
hdchique
Posted: 04.Mar.2010 at 18:01 |
Thanks for the suggestions. I have found -
I appreciate the help! |
Post Reply | |
Tweet
This page was generated in 0,334 seconds.
