Discussion forum
CAD discussion |
Budweiser2008.dwg released |
Post Reply |
Author | |
Vladimir Michl
Topic: Budweiser2008.dwg released Posted: 06.Aug.2007 at 14:11 |
XANADU has just released a new version of the well-known benchmark drawing - BUDWEISER.DWG. The Budweiser2008.dwg tests the DWG2007 file format with drawing objects from plain AutoCAD 2008.
You can test the compatibility of your non-Autodesk CAD application claiming "100%-compatibility" with DWG file format.
More information on www.xanadu.cz/budweiser
Vladimir Michl (moderator)
Post Reply | |
Tweet
This page was generated in 0,695 seconds.
