Discussion forum
CAD discussion |
help with pass polyfaces to 3dfaces |
Post Reply |
Author | |
arte16
Newbie Joined: 07.Oct.2009 Status: Offline Points: 1 |
Topic: help with pass polyfaces to 3dfaces Posted: 02.Jul.2010 at 08:20 |
Hello
Good morning
I am working with Autocad 2008 and I need to pass an object that is in Polyfaces to 3DFaces, someone tell me how ????? Thank you so much |
Vladimir Michl
Moderator Group Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2018 |
Posted: 02.Jul.2010 at 11:50 |
EXPLODE ? |
Vladimir Michl (moderator)
Arkance Systems - arkance-systems.cz - Autodesk reseller |
msplcdykee69
Senior Member Joined: 15.Dec.2008 Location: United States Using: Civil 3D, Map, Inventor, Mechanical, & Electrical Status: Offline Points: 163 |
Posted: 02.Jul.2010 at 14:19 |
You can try this,
You can convert 3D Faces into Regions with the _.Region command. You can convert Meshes into 3D Faces with the _.Explode command, then convert the 3D Faces into Regions ( see above ). Regions can be used as Hatch Boundaries. Try that... If that does not work look on this site in tips and tricks. |
Engineering Manufacturing Medical Cables/Adjunct Instructor Engineering Graphics/Engineering Computations and Careers
msplcdykee69@yahoo.com Shawn |
Post Reply | |
Tweet
This page was generated in 0,387 seconds.
